Almond ' Home Assisttant did not hear anything'
I have HASSIO running ( a VM on KVM ). I am running DuckDNS with Letsencrypt. I installed Almond a while ago and it was working and not it stopped working, when I tape the mic in the Android app, I get the message “Home Assistant did not hear anything”. I removed Almond and reinstalled it but no avail. I see the following in my log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] almond.sh: executing...
[cont-init.d] almond.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2021/01/24 03:33:35 [notice] 207#207: using the "epoll" event method
2021/01/24 03:33:35 [notice] 207#207: nginx/1.14.2
2021/01/24 03:33:35 [notice] 207#207: OS: Linux 5.4.86
2021/01/24 03:33:35 [notice] 207#207: getrlimit(RLIMIT_NOFILE): 1048576:1048576
2021/01/24 03:33:35 [notice] 207#207: start worker processes
2021/01/24 03:33:35 [notice] 207#207: start worker process 237
Unable to load crypto module: crypto will be disabled: Error: global.Olm is not defined
Frontend initialized in development mode
Failed to load translations: gt.loadTextdomainDirectory is not a function
BaseDevice.engine is deprecated and should not be used in new code.
Added device thingengine-own-server:807640248f74f6ba
Added device thingengine-own-global
Added device org.thingpedia.builtin.thingengine.remote
Added device org.thingpedia.builtin.test
Engine started
Express server listening on port 3000
Ready
Engine running
Loaded class definition for io.home-assistant, module type: org.thingpedia.v2, version: 21
[22:33:38] INFO: Successfully send discovery information to Home Assistant.
Added device io.home-assistant/http://supervisor/homeassistant
Home Assistant: connection attempt 1/10
{"uniqueId":"io.home-assistant/http://supervisor/homeassistant","name":"Home Assistant Gateway at http://supervisor/homeassistant","description":"This is your Home Assistant Gateway.","kind":"io.home-assistant","ownerTier":"global"}POST /api/devices/create 200 202.308 ms - 232
[22:33:38] INFO: Successfully register local Home Assistant on Almond
Unhandled Home Assistant entity binary_sensor.washer_wash_completed with domain binary_sensor and device class undefined
Unhandled Home Assistant entity binary_sensor.washer_error_state with domain binary_sensor and device class problem
Unhandled Home Assistant entity sensor.washer with domain sensor and device class undefined
Unhandled Home Assistant entity media_player.remote_player with domain media_player and device class undefined
