The usage environment is DOCKER+HOMEASISTANT2024.4.3
Here are the logs, I need help!
2024-04-21 01:15:58.723 ERROR (MainThread) [custom_components.xiaomi_miio_airconditioningcompanion.climate] Device unavailable or token incorrect: Unable to discover the device 192.168.0.231
2024-04-21 01:15:58.724 WARNING (MainThread) [homeassistant.components.climate] Platform xiaomi_miio_airconditioningcompanion not ready yet: None; Retrying in background in 30 seconds
2024-04-21 01:15:59.000 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'panel_iframe' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/panel_iframe/__init__.py, line 14: hass.components.frontend.add_extra_js_url(hass, f'/panel_iframe_www/panel_iframe.js?v={VERSION}'), please report it to the author of the 'panel_iframe' custom integration
2024-04-21 01:15:59.019 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry ezviz_cn-36b03627 for ezviz
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 551, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/ezviz/__init__.py", line 56, in async_setup_entry
sensor_type: str = entry.data[CONF_TYPE]
KeyError: 'type'
2024-04-21 01:15:59.575 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_AUTO was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.AUTO instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.582 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_COOL was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.COOL instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.587 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_DRY was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.DRY instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.591 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_FAN_ONLY was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.FAN_ONLY instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.597 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_HEAT was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.HEAT instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.601 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_HEAT_COOL was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.HEAT_COOL instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.606 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_OFF was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.OFF instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.610 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_AUX_HEAT was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.AUX_HEAT instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.615 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_FAN_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.FAN_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.620 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_PRESET_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.PRESET_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.626 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_SWING_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.SWING_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.632 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_TARGET_HUMIDITY was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_HUMIDITY instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.638 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_TARGET_TEMPERATURE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_TEMPERATURE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.644 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_TARGET_TEMPERATURE_RANGE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_TEMPERATURE_RANGE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.650 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_AUTO was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.AUTO instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.656 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_COOL was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.COOL instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.662 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_DRY was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.DRY instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.667 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_FAN_ONLY was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.FAN_ONLY instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.672 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_HEAT was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.HEAT instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.678 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_HEAT_COOL was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.HEAT_COOL instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.683 WARNING (ImportExecutor_0) [homeassistant.components.climate] HVAC_MODE_OFF was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.OFF instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.689 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_AUX_HEAT was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.AUX_HEAT instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.695 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_FAN_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.FAN_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.701 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_PRESET_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.PRESET_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.714 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_SWING_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.SWING_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.719 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_TARGET_HUMIDITY was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_HUMIDITY instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.724 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_TARGET_TEMPERATURE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_TEMPERATURE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.730 WARNING (ImportExecutor_0) [homeassistant.components.climate] SUPPORT_TARGET_TEMPERATURE_RANGE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_TEMPERATURE_RANGE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.736 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] HVAC_MODE_OFF was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.OFF instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.741 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] HVAC_MODE_HEAT was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.HEAT instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.746 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] HVAC_MODE_COOL was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.COOL instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.752 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] HVAC_MODE_HEAT_COOL was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.HEAT_COOL instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.757 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] HVAC_MODE_AUTO was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.AUTO instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.764 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] HVAC_MODE_DRY was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.DRY instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.771 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] HVAC_MODE_FAN_ONLY was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.FAN_ONLY instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.777 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] CURRENT_HVAC_OFF was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACAction.OFF instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.782 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] CURRENT_HVAC_HEAT was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACAction.HEATING instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.788 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] CURRENT_HVAC_COOL was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACAction.COOLING instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.794 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] CURRENT_HVAC_DRY was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACAction.DRYING instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.800 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] CURRENT_HVAC_IDLE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACAction.IDLE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.805 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] CURRENT_HVAC_FAN was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACAction.FAN instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.811 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] SUPPORT_TARGET_TEMPERATURE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_TEMPERATURE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.817 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] SUPPORT_TARGET_TEMPERATURE_RANGE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_TEMPERATURE_RANGE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.823 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] SUPPORT_TARGET_HUMIDITY was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_HUMIDITY instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.829 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] SUPPORT_FAN_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.FAN_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.834 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] SUPPORT_PRESET_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.PRESET_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.840 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] SUPPORT_SWING_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.SWING_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.845 WARNING (ImportExecutor_0) [homeassistant.components.climate.const] SUPPORT_AUX_HEAT was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.AUX_HEAT instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.852 WARNING (ImportExecutor_0) [homeassistant.const] TEMP_CELSIUS was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTemperature.CELSIUS instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.870 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_SET_SPEED was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.SET_SPEED instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.876 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_OSCILLATE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.OSCILLATE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.882 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_DIRECTION was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.DIRECTION instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.888 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_PRESET_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.PRESET_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.894 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_SET_SPEED was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.SET_SPEED instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.899 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_OSCILLATE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.OSCILLATE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.905 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_DIRECTION was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.DIRECTION instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.912 WARNING (ImportExecutor_0) [homeassistant.components.fan] SUPPORT_PRESET_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use FanEntityFeature.PRESET_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:15:59.915 WARNING (MainThread) [homeassistant.helpers.entity] Entity midea_ac_lan.1099512654225_fan (<class 'custom_components.midea_ac_lan.fan.MideaFAFan'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <FanEntityFeature.SET_SPEED|OSCILLATE|PRESET_MODE: 11>, please create a bug report at https://github.com/georgezhao2010/midea_ac_lan/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-04-21 01:15:59.916 WARNING (MainThread) [homeassistant.helpers.entity] Entity midea_ac_lan.72567767436454_fan (<class 'custom_components.midea_ac_lan.fan.MideaFAFan'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <FanEntityFeature.SET_SPEED|OSCILLATE|PRESET_MODE: 11>, please create a bug report at https://github.com/georgezhao2010/midea_ac_lan/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-04-21 01:16:00.237 WARNING (ImportExecutor_0) [homeassistant.components.water_heater] SUPPORT_TARGET_TEMPERATURE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use WaterHeaterEntityFeature.TARGET_TEMPERATURE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.242 WARNING (ImportExecutor_0) [homeassistant.components.water_heater] SUPPORT_OPERATION_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use WaterHeaterEntityFeature.OPERATION_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.247 WARNING (ImportExecutor_0) [homeassistant.components.water_heater] SUPPORT_AWAY_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use WaterHeaterEntityFeature.AWAY_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.252 WARNING (ImportExecutor_0) [homeassistant.components.water_heater] SUPPORT_TARGET_TEMPERATURE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use WaterHeaterEntityFeature.TARGET_TEMPERATURE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.256 WARNING (ImportExecutor_0) [homeassistant.components.water_heater] SUPPORT_OPERATION_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use WaterHeaterEntityFeature.OPERATION_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.261 WARNING (ImportExecutor_0) [homeassistant.components.water_heater] SUPPORT_AWAY_MODE was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use WaterHeaterEntityFeature.AWAY_MODE instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.266 WARNING (ImportExecutor_0) [homeassistant.const] TEMP_CELSIUS was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTemperature.CELSIUS instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.280 WARNING (ImportExecutor_0) [homeassistant.components.humidifier] DEVICE_CLASS_DEHUMIDIFIER was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HumidifierDeviceClass.DEHUMIDIFIER instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.285 WARNING (ImportExecutor_0) [homeassistant.components.humidifier] DEVICE_CLASS_HUMIDIFIER was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HumidifierDeviceClass.HUMIDIFIER instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.290 WARNING (ImportExecutor_0) [homeassistant.components.humidifier] SUPPORT_MODES was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HumidifierEntityFeature.MODES instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.295 WARNING (ImportExecutor_0) [homeassistant.components.humidifier] DEVICE_CLASS_DEHUMIDIFIER was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HumidifierDeviceClass.DEHUMIDIFIER instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.300 WARNING (ImportExecutor_0) [homeassistant.components.humidifier] DEVICE_CLASS_HUMIDIFIER was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HumidifierDeviceClass.HUMIDIFIER instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.304 WARNING (ImportExecutor_0) [homeassistant.components.humidifier] SUPPORT_MODES was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HumidifierEntityFeature.MODES instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.310 WARNING (ImportExecutor_0) [homeassistant.components.humidifier.const] DEVICE_CLASS_HUMIDIFIER was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HumidifierDeviceClass.HUMIDIFIER instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.314 WARNING (ImportExecutor_0) [homeassistant.components.humidifier.const] DEVICE_CLASS_DEHUMIDIFIER was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HumidifierDeviceClass.DEHUMIDIFIER instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:00.320 WARNING (ImportExecutor_0) [homeassistant.components.humidifier.const] SUPPORT_MODES was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use HumidifierEntityFeature.MODES instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-04-21 01:16:03.647 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for espcam @ 192.168.0.128: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.0.128', port=6053))]: [Errno 113] Connect call failed ('192.168.0.128', 6053) (SocketAPIError)
2024-04-21 01:16:03.652 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for phicomm_dc1 @ 192.168.0.48: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.0.48', port=6053))]: [Errno 113] Connect call failed ('192.168.0.48', 6053) (SocketAPIError)
2024-04-21 01:16:03.654 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for legoled @ 192.168.0.121: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.0.121', port=6053))]: [Errno 113] Connect call failed ('192.168.0.121', 6053) (SocketAPIError)
2024-04-21 01:16:03.655 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for rf-bridge @ 192.168.0.35: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.0.35', port=6053))]: [Errno 113] Connect call failed ('192.168.0.35', 6053) (SocketAPIError)
2024-04-21 01:16:03.656 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for esp32s3 @ 192.168.0.66: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.0.66', port=6053))]: [Errno 113] Connect call failed ('192.168.0.66', 6053) (SocketAPIError)
2024-04-21 01:16:14.063 ERROR (MainThread) [custom_components.xiaomi_miio_airconditioningcompanion.climate] Device unavailable or token incorrect: Unable to discover the device 192.168.0.231
2024-04-21 01:16:25.533 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running!
2024-04-21 01:16:47.687 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration caiyun which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-21 01:16:47.696 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration panel_iframe which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-21 01:16:47.697 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration midea_ac_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-21 01:16:47.698 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hasslife which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-21 01:16:47.698 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration updater which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-21 01:16:47.699 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pyscript which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-21 01:16:47.702 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-21 01:16:47.703 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_gateway3 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-21 01:16:47.703 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_miio_airconditioningcompanion which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-21 01:16:50.153 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 350, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 557, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message:
Invalid method encountered:
b'\x16\x03\x01\x06\xfd\x01'
2024-04-21 01:16:50.162 ERROR (MainThread) [aiohttp.server] Error handling request
b'\x16\x03\x01\x06\xdd\x01'
2024-04-21 01:16:51.965 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running!
2024-04-21 01:17:19.070 ERROR (MainThread) [custom_components.xiaomi_miio_airconditioningcompanion.climate] Device unavailable or token incorrect: Unable to discover the device 192.168.0.231
