I want to be able to trigger automations when my camera spot a certain car (the plate). My setup is Home assistant (on the “blue”, odroid - box), cameras connected to Blue Iris. In BI there is a ALPR function. The APLR function works ok (not great, but ok). If I log in on https://app.platerecognizer.com/dashboard, I can see the results. But as I mentioned, I want to be able to use the results in Home Assistant.
For person alerts I have created a MQTT event and that works great. I can use that in HA. But I don’t know how to make my license plates to work.
I have under the “Required AI object” in Blue Iris written my license plates. I guess this is wrong - but I don’t know what else to do. Thankful for any help! Over and out,
/Fanan
If you find out anything, please share any possible solution, I also just set it up, got plates recognized quite fairly, I can see the actual plates in BI log, but I can’t find out:
how to send them to home assistant
how to build a database of the recognized license plates,
and how to make automation on certain plates (like open gate for friend’s or family member’s plate)
Would be supercool to use it these kind of automations
I just did it, too, fantastic. I also set up the face recognition, and that also works fantastic.
For faces, I followed this comment:
I like it very much since it gives me options what to do in case a person was recognized (to open the gate for example), and what to do if the person in front of my gate is a stranger (then not to open the gate, but rather notify me on my phone).
Could I do something similar with plate recognition? Somehow integrate the watched plates sensors as conditions? I’d really appreciate some advice on this.
No worries if I find anything useful I’ll let you know! Have fun with HA, I can’t stop playing with it since I found it a year ago, I accomplished sooo much, and I’m only scratching the surface and not even a programmer…
