Also stuck for Siemens Home Connect integration
Hello
I read previous forum topics about this, and I really do not understand what to do. I read also other posts to no avail.
Now the question is that recently, Siemens asked to use SingleKey Ids ? did any one manage to make Home Connect integration work with this new log in method?
My problem is similar to : Stuck for days on Siemens Home Connect Integration - Help needed
When adding the integration, everything works fine until I press “Link account”, then a window say error, and it is in the log here below
Capture d’écran 2023-02-26 093819
The error Error: 400, message=‘Bad Request’, url=URL(‘https://api.home-connect.com/security/oauth/token’)
in the log file after trying to connect.
I read the instructions and did everything accordingly.
Not sure which screen shot you would like to see, but I have all the tokens set up
Here is on home connect
thanks
I have the same problem, moreover I’m not able to use the Home Connect Dev account to see my dishwasher. It looks like, the change to SingleKey ID has changed the way to acces the devices?
I‘m using
As it has more sensors and information about my dishwasher
And it is working fine
