Alternative Nabu Casa haaska alexa
With this “solution” it is possible to command HomeAssistant from Alexa without having to EXPRESS ENTITY and without using Nabo or haaska and AWS.
Requirement
Installation
Create a group with all entities media_player alexa
group:
  echos:
    entities:
      - media_player.camera_2
      - media_player.studio
Add sensor to detect the last sentence spoken
    sensors:
      last_called_summary:
        value_template: >
              {% set media =expand(states.group.echos)|selectattr('attributes.last_called','eq',true)|map(attribute='entity_id')|first%}
              {{ state_attr(media,'last_called_summary')|regex_replace(find='alexa ') }}
Use the sensor as an automation trigger.
automation:
  - alias: Alexa
    initial_state: true
    mode: single
    max_exceeded: silent
    - platform: state
      entity_id: sensor.last_called_summary
      to:
        - 'spegni luce studio'
        - 'spegni la luce dello studio'
    - service: switch.turn_off
        entity_id: switch.luce_studio
To avoid getting “error” messages from alexa, create a routine in the Alexa mobile application with (when this happens) the phrase used in the trigger, and as an action the response you want to get
