This Blueprint for each configured plant, checks its status and notifies if there are any problems.
This blueprint works in conjunction with “Alternative plants component for Home Assistant”.
blueprint:
name: Alternative Plant problem notification
description: |
For each configured plant, checks its status and notifies if there are any problems.
This blueprint works in conjunction with "Alternative plants component for Home Assistant".
* https://github.com/Olen/homeassistant-plant
domain: automation
author: Alex Soto Aguilera
source_url: https://gist.github.com/alexsotoaguilera/462e40dcbc40a0fa0dd460755ef3defa
homeassistant:
min_version: 2022.4.0
input:
notification_time:
name: Time to check all plant sensors
description: The verification of the plant sensors takes place within the configured time.
default: '10:00:00'
selector:
time: {}
exclude:
description: Plants to exclude from report.
default:
entity_id: []
selector:
entity:
- device_class:
- plant
devices_to_notify:
name: Devices to notify
description: Device needs to run the official Home Assistant app to receive notifications.
default: []
selector:
device:
filter:
- integration: mobile_app
multiple: true
variables:
exclude_plant_entities: !input exclude
notify_plant_entities: |
{% set plant_entities = states.plant | map(attribute='entity_id') | select('is_state', 'problem') | list %}
{% set data = namespace(notify_entities=[]) %}
{% for plant_entity in plant_entities %}
{% if plant_entity not in exclude_plant_entities %}
{% set data.notify_entities = data.notify_entities + [plant_entity] %}
{% endif %}
{% endfor %}
{{ data.notify_entities }}
- platform: time
at: !input 'notification_time'
- repeat:
for_each: !input 'devices_to_notify'
sequence:
- variables:
device_to_notify: "{{ repeat.item }}"
- repeat:
for_each: "{{ notify_plant_entities }}"
sequence:
- service: "notify.mobile_app_{{ device_attr(device_to_notify, 'name') | slugify }}"
title: "Plant WARNING: {{ state_attr(repeat.item, 'friendly_name') }}."
message: |
{% set plant_sensors = device_entities(device_id(repeat.item)) | select('is_state_attr', 'state_class', 'measurement') | list -%}
{% for sensor in plant_sensors -%}
{% if not is_state(sensor, 'unknown') -%}
- {{ state_attr(sensor, 'device_class') }} {{ states(sensor) }}{{ state_attr(sensor, 'unit_of_measurement') }}
{% endif -%}
{% endfor -%}
mode: single
Changelog
- November 2, 2024: Initial release
- November 10, 2024: Fixed truncation in notification splitting in one notification per plant
