Alternative to DHT22 for simple temp solution?
So I have just purchased a Pi4 for my motorhome to control most of my electrics but after purchasing a DHT22 I have discovered that there is a problem with Adafruit libraries and cannot be used until fixed.
Im looking for simple/cheap alternatives to get temp readings that my heating/cooling can react to.
Thanks for any suggestions on this…im surprised the pi4/dht combo isnt mentioned in the official docs.
Thanks for any suggestions on this.
1-wire DS18S20, https://www.home-assistant.io/integrations/onewire/
Or maybe one of the Bluetooth sensors from Xiaomi, https://www.home-assistant.io/integrations/mitemp_bt/
Hi
how do you run your Homeassistant in the motorhome?
Do you run it on a Hotspot?
It’s mostly a local setup as far as controls go…
But for my motorhome network I have an Archer C50 router that I have flashed with OpenWrt. When parked near wifi (or switch on my phone hotspot) I can set the 2.4ghz band to connect to the wifi/hotspot and reshare locally over eth and 5ghz band to all my smarts.
So i have a constant local network for motorhome via 5hz and eth… then use the 2.4ghz band to connecto to an internet source when available which gets shared to the local network.
Do you have any documentation or link to share to make the raspberrypi as local setup
i would love to run my accessory locally on Homeassisant
It runs locally as standard…just connect your homeassistant to your LAN via wifi or ethernet. Do the same with all of your smart devices. Then go to integrations in homeassistant and add all of your devices that are on the same network.
last question…
i got one running at home on the ethernet but i trying to figure how could i run a second Home Assistant in my MotorHome when i am not connected to nay ethernet
how do you HomeAssisant on a Hotspot?
The simplest way would be to create a network config file on a usb with your hotpsot details in that homeassistant will read on startup…
^ Think this should tell you how to do it
Actually…just follow the wifi instructions under ‘installation’ on this page, much simpler:
Tempsensor
Xiaomi sensors run off small battery(compact and no wires showing) and BMP(Not inside a project case yet so heats up bit quicker and cools down quicker running on Tasmota. May be prone to heat creep from ESP board if not seperated. Easy to offset temp) here on a ESP32 running off old phone charger. Both show up easily on Home Assistant.
Thanks Spiro, I actually went with some 1-wire sensors which have been great and cheap
