Hi all, I’m new to Home Assistant so excuse my ignorance if I have broken something…
Now, I know that the UK is in a current state of lockdown but my HA Badge (and associated history) constantly says I’m home even though I’m not.
Any ideas what’s going wrong?
What are you using as a trigger for home/away? Android app? Beacon?
It uses the source “device_tracker.sm_g950u” which is my Android phone, and the device that HA assigned on initial install
The simplest test then is to turn off your phone and see if you are then “away”. Failing that make sure the app is set up correctly.
