Although I’ve already had answers about the automatic restart of HA after the following error, and although I’ve already tried to disable almost all the custom components, I still have this problem. Is it possible that no other user has experienced similar behavior?
Log is the following:
2023-03-23 04:36:46.088 ERROR (MainThread) [root] Uncaught exception
File "/usr/local/lib/python3.10/runpy.py", line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.10/runpy.py", line 86, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 226, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 214, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 179, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 636, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 603, in run_forever
self._run_once()
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1882, in _run_once
handle = heapq.heappop(self._scheduled)
RuntimeError: list changed size during iteration
I have installed only default integrations and some of the custom ones, i tried also to disable some of them, but nothing… the problem occurs almost every day.
What to do?
RuntimeError: Executor shutdown has been called
2024-01-17 09:58:25.460 ERROR (MainThread) [homeassistant.components.mqtt.models] Exception raised when updating state of sensor.weatherflow_xmpp_wind_speed, topic: 'homeassistant/sensor/weatherflow2mqtt_ST-00088363/rapid_wind/state' with payload: b'{"wind_speed": 3.87, "wind_bearing": 352, "wind_direction": "N"}'
File "/usr/src/homeassistant/homeassistant/runner.py", line 188, in run
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 640, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 607, in run_forever
self._run_once()
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1873, in _run_once
