I have the following two automations, yet only one fires:
- id: '1601596911646'
alias: 'Climate: Morning Heat'
description: ''
- platform: time
at: '06:00'
condition:
- type: is_value
condition: device
device_id: 64467e70043c11eba2640f5929640a8e
entity_id: sensor.honeywell_th6320zw2003_t6_pro_series_thermostat_temperature
domain: sensor
below: 73
- service: climate.set_temperature
temperature: 69
entity_id: climate.honeywell_th6320zw2003_t6_pro_series_thermostat_mode
mode: single
and
- id: '1601597049514'
alias: 'Climate: Night Heat'
description: ''
- platform: time
at: '22:00'
condition:
- type: is_value
condition: device
domain: sensor
below: 73
temperature: 64
mode: single
It appears that only the first one created fires, and the second one never does. As can be seen, these are nearly identical, with the only difference being the time they fire, and the temperature being set.
I am at a loss for what could be causing this issue. What am I missing?
