AM43 BLIND MOTOR losing connection BT to ESP32
I have two AM43 motors connected on Bluetooth to a ESP32
this is my code
# esp32 blinds #
# Substitutions
substitutions:
  # Device Names
  device_name: "esp32_blinds"
  friendly_name: "ESP32-BLINDS"
esphome:
  platform: ESP32
  board: nodemcu-32s
wifi:
  ssid: ""
  password: ""
  manual_ip:
   static_ip: 192.168.0.141
   gateway: 192.168.0.2
   subnet: 255.255.255.0
   dns1: 192.168.0.2
  ap:
    ssid: "Esp32-Blinds Fallback Hotspot"
    password: "ZID1ELiDRHfM"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
# Enable OTA #
ota:
# Enable Web server #
web_server:
  port: 80
time:
  - platform: homeassistant
# Device Status #
binary_sensor:
  - platform: status
    name: "${friendly_name} Device Status"
text_sensor:
# ESP Version #
  - platform: version
    name: "${friendly_name} ESPHome Version"
    name: Uptime Human Readable
    icon: mdi:clock-start
# WiFi info #
  - platform: wifi_info
    ip_address:
      name: ESP IP Address ${friendly_name}
    ssid:
      name: ESP Connected SSID ${friendly_name}
    bssid:
      name: ESP Connected BSSID ${friendly_name}
# Bluetooth  #
esp32_ble_tracker:
# Bluetooth Blinds #
ble_client:
  - mac_address: 02:83:2A:C0:3E:26
  - mac_address: 02:5A:72:F2:2A:65
  - platform: am43
    ble_client_id: am43_lounge_left
    battery_level:
      name: "Lounge Blind Left Battery"
    illuminance:
      name: "Lounge Blind Left light"
  - platform: am43
    ble_client_id: am43_lounge_right
    battery_level:
      name: "Lounge Blind Right Battery"
    illuminance:
      name: "Lounge Blind Right light"
# Device Sensors #
  - platform: uptime
    update_interval: 60s
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? to_string(days) + "d " : "") +
                (hours ? to_string(hours) + "h " : "") +
                (minutes ? to_string(minutes) + "m " : "") +
                (to_string(seconds) + "s")
              ).c_str();
# WiFi Signal Sensor
  - platform: wifi_signal
    name: "${friendly_name} WiFi Status"
# Uptime #
  - platform: uptime
cover:
  - platform: am43
    name: "Lounge Blinds Left"
    invert_position: false
    pin: 8888
  - platform: am43
    name: "Lounge Blinds Right"
    pin: 8888
switch:
  - platform: restart
status_led:
  pin:
    number: GPIO2
    inverted: TRUE
My issue is that from time to time it appears as if the ESP loses connection Bluetooth to the AM43.
To reestablish the connection I toggle the restart switch.
I would like to automate this say for example is it possible for the ESP to “ping” the Bluetooth mac address say every 30 minutes, and say if it does not get a response to toggle the restart?
The Wi-Fi to the ESP32 is fine and never loses connection, so that is why I am suspecting it is the Bluetooth part of the connection.
Has anyone else had this issue?
Regards,
Hello, I have the same problem, did you resolve it?
Thanks!
