Summary
I was after making my own dashboard to monitor HF conditions for amateur/ham radio, using the excellent data and services provide by N0NBH’s HF Propagation Tools and Solar Data and KC2G for ionospheric conditions. Screenshot below:
Details
Sensors
N0NBH provides a XML output of the data, which can be polled hourly. The multiscrape custom component is ideal for this, with the following configuration to pick out key things I was interested in.
multiscrape:
resource: https://www.hamqsl.com/solarxml.php
scan_interval: 3600
- unique_id: solar_flux_index
name: "Solar Flux Index"
select: "solarflux"
value_template: '{{ value.strip()|int }}'
state_class: measurement
icon: mdi:weather-sunny-alert
- unique_id: solar_sunspots
name: "Solar Sunspots"
select: "sunspots"
- unique_id: solar_a_index
select: "aindex"
icon: mdi:alpha-a
- unique_id: solar_k_index
select: "kindex"
icon: mdi:alpha-k
- unique_id: solar_bz
select: "magneticfield"
value_template: '{{ value.strip()|float }}'
icon: mdi:sun-compass
- unique_id: solar_wind
select: "solarwind"
icon: mdi:sun-wireless
unit_of_measurement: km/s
- unique_id: solar_hf_80_40_day
name: "HF Conditions 80m-40m Day"
select: 'band[name="80m-40m"][time="day"]'
icon: mdi:sine-wave
- unique_id: solar_hf_30_20_day
name: "HF Conditions 30m-20m Day"
select: 'band[name="30m-20m"][time="day"]'
icon: mdi:sine-wave
- unique_id: solar_hf_17_15_day
name: "HF Conditions 17m-15m Day"
select: 'band[name="17m-15m"][time="day"]'
icon: mdi:sine-wave
- unique_id: solar_hf_12_10_day
name: "HF Conditions 12m-10m Day"
select: 'band[name="12m-10m"][time="day"]'
icon: mdi:sine-wave
- unique_id: solar_hf_80_40_night
name: "HF Conditions 80m-40m Night"
select: 'band[name="80m-40m"][time="night"]'
icon: mdi:sine-wave
- unique_id: solar_hf_30_20_night
name: "HF Conditions 30m-20m Night"
select: 'band[name="30m-20m"][time="night"]'
icon: mdi:sine-wave
- unique_id: solar_hf_17_15_night
name: "HF Conditions 17m-15m Night"
select: 'band[name="17m-15m"][time="night"]'
icon: mdi:sine-wave
- unique_id: solar_hf_12_10_night
name: "HF Conditions 12m-10m Night"
select: 'band[name="12m-10m"][time="night"]'
icon: mdi:sine-wave
- unique_id: solar_geomag_field
name: "HF Conditions Geomag Field"
select: 'geomagfield'
icon: mdi:compass
- unique_id: solar_sig_noise_lvl
name: "HF Conditions Noise Level"
select: 'signalnoise'
icon: mdi:signal-cellular-2
value_template: '{{ value.strip()[1] | int }}'
For fetching local maximum usable frequency (MUF) from KC2G’s site, I used the standard rest sensor, with JSON station data resource. Note you will need to inspect the JSON file per resource below, and replace the ?????
with the station code closest to you.
- platform: rest
name: "Solar HF MUF"
resource: 'https://prop.kc2g.com/api/stations.json'
value_template: '{{ (value_json | selectattr("station.code", "==", "?????") | list | first).mufd | float(default=float("NaN")) }}'
scan_interval: 600
unit_of_measurement: MHz
Dashboard
For this I used great lovelace addon mini-graph-card
. Obviously you may want to tweak the colours, layout, etc. to suit your needs.
cards:
- square: false
columns: 2
type: grid
cards:
- type: custom:mini-graph-card
name: Solar Flux Index
font_size: 75
hour24: true
hours_to_show: 48
upper_bound: 250
lower_bound: 50
min_bound_range: 200
show:
icon: true
entities:
- entity: sensor.solar_flux_index
state_adaptive_color: true
color_thresholds:
- value: 80
color: '#ff0000'
- '#ffbf00'
- value: 150
color: '#00ff00'
font_size: 75
hours_to_show: 48
hour24: true
upper_bound: 200
lower_bound: 20
show:
icon: true
entities:
- entity: sensor.solar_sunspots
color_thresholds:
- value: 20
color: '#ff0000'
- '#ffbf00'
- value: 100
color: '#00ff00'
font_size: 75
hour24: true
hours_to_show: 48
upper_bound: 50
lower_bound: 0
min_bound_range: 30
show:
icon: true
entities:
- entity: sensor.solar_a_index
color_thresholds:
- value: 50
color: '#ff0000'
- '#ffbf00'
- value: 0
color: '#00ff00'
font_size: 75
hours_to_show: 48
hour24: true
upper_bound: 9
lower_bound: 0
min_bound_range: 9
show:
icon: true
entities:
- entity: sensor.solar_k_index
color_thresholds:
- value: 8
color: '#ff0000'
- value: 4
color: '#ffbf00'
- value: 1
color: '#00ff00'
font_size: 75
hour24: true
hours_to_show: 48
upper_bound: 20
lower_bound: -20
min_bound_range: 40
show:
icon: true
entities:
- entity: sensor.solar_bz
color_thresholds:
- value: -20
color: '#ff0000'
- '#ffbf00'
- value: 0
color: '#00ff00'
- '#ffbf00'
- value: 20
color: '#00ff00'
font_size: 75
hours_to_show: 48
hour24: true
upper_bound: 700
lower_bound: 200
min_bound_range: 500
show:
icon: true
entities:
- entity: sensor.solar_wind
color_thresholds:
- value: 700
color: '#ff0000'
- '#ffbf00'
- value: 300
color: '#00ff00'
- square: false
columns: 2
type: grid
cards:
font_size: 75
hours_to_show: 48
hour24: true
upper_bound: 30
lower_bound: 7
min_bound_range: 23
show:
labels: hover
entities:
- entity: sensor.solar_hf_muf
color_thresholds:
- value: 3
color: '#ff0000'
- value: 14
color: '#ffbf00'
- value: 28
color: '#00ff00'
font_size: 75
unit: S-units
hours_to_show: 48
hour24: true
upper_bound: 9
lower_bound: 0
min_bound_range: 7
show:
labels: hover
entities:
- entity: sensor.solar_sig_noise_lvl
color_thresholds:
- value: 6
color: '#ff0000'
- '#ffbf00'
- value: 1
color: '#00ff00'
font_size: 75
name: 80m - 40m
hours_to_show: 48
hour24: true
upper_bound: 2
lower_bound: 0
min_bound_range: 2
show:
legend: false
entities:
- entity: sensor.solar_hf_80_40_day
show_state: true
- entity: sensor.solar_hf_80_40_night
show_state: true
state_map:
- value: Poor
label: Poor
- value: Fair
label: Fair
- value: Good
label: Good
smoothing: false
font_size: 75
name: 30m - 20m
hours_to_show: 48
hour24: true
upper_bound: 2
lower_bound: 0
min_bound_range: 2
show:
legend: false
entities:
- entity: sensor.solar_hf_30_20_day
show_state: true
- entity: sensor.solar_hf_30_20_night
show_state: true
state_map:
- value: Poor
label: Poor
- value: Fair
label: Fair
- value: Good
label: Good
smoothing: false
font_size: 75
name: 17m - 15m
hours_to_show: 48
hour24: true
upper_bound: 2
lower_bound: 0
min_bound_range: 2
show:
legend: false
entities:
- entity: sensor.solar_hf_17_15_day
show_state: true
- entity: sensor.solar_hf_17_15_night
show_state: true
state_map:
- value: Poor
label: Poor
- value: Fair
label: Fair
- value: Good
label: Good
smoothing: false
font_size: 75
name: 12m - 10m
hours_to_show: 48
hour24: true
upper_bound: 2
lower_bound: 0
min_bound_range: 2
show:
legend: false
entities:
- entity: sensor.solar_hf_12_10_day
show_state: true
- entity: sensor.solar_hf_12_10_night
show_state: true
state_map:
- value: Poor
label: Poor
- value: Fair
label: Fair
- value: Good
label: Good
smoothing: false
