Amazon Basics Single Pole Smart Dimmer Switch, Neutral Wire Required, 2.4 Ghz
Has anyone tried these? I don’t see an integration for HA, but maybe I’m missing something.
From the feedback on Amazon:
If you are looking for integration with Home Assistant avoid these.
Alexa <-> Node-RED <-> Home Assistant integration
I suggest you look at Smart Switch by Martin Jerry with TASMOTA. It is currently $14, while Amazon is $20.
With TASMOTA, you will need MQTT like the MosquittoMQTT that comes with HA.
