I have check that emulated hue is running as per the component documentation and it looks all good. I am only exposing 2 devices so I dont think I am hitting any sort of a limit.
Any ideas why the Echo is not able to discover my emulated hue devices?
The problem being that sometimes the system may pick up the wrong IP (docker containers for example, you’ll get the IP of the container not the host), and in such circumstances you set it manually with that option
