I pushed translations too, but seems like something is wrong with last 3 fields. Just checked, in the app they are called UID Panel Code (looong string), Username, Password. Check them again, try again?
Worst case try calling it directly from python, see what it gives you back.
Now it is oke. I dont know how to call it directly from python as iām not developer, but i have another idea. I will delete account from the app and log it again.It will ask me for panel uid.
If this works then something is wrong with thus integration. Let me check it over an app.
Ok Iām in.
For username you should use username for cloud and password for cloud. That is how i got in.
But now I donāt have any devices or entities in integration.
Hmmā¦ Try enabling debug logs, then reload integration from integration menu. Wait couple of minutes.
Then disable debug logs - HASS will offer to download them. Edit out sensitive information (first lines where login happens) and send to [email protected] or private gist. Iāll try to reproduce it based on your data.
I did enabled debug logging. amc alarm api is authorized and i get a lot of data in log from central and pir sensors. But no entities yet.
I will try to anonymize this and send you on mail.
I noticed with version 0.0.2 that integration became unavailable. Reloading it or restarting ha became available again but it frequently became unavailable.
Oh man, you did an awesome job!
I havenāt tested it fully yet, but it seems to work ok, Iāll have a deeper look later and give you a better feedback. But thatās great indeed!
