Amcrest AD110 Ring Dorbell FFMPEG Befehl
Hello, my dears,
when I’m in the console in the Home Assistant I can’t run the “ffmpeg” command. Will not be found. Just a command with underscore “_ffmpeg”. If I run this I get the following message: “_arguments: comparguments: 327. can only called from completion functions” Do I have to install anything else?
Greetings from Stefan Harbich
the solution was ffmpeg in the docker container above
apk add ffmpeg
to install.
