- service: notify.mitv_notify
message: hi
duration: 7
fontsize: large
color: green
position: center
file:
path: /config/www/camsnapshot/cameradoor.png
i would like to show the RTSP of the camera on my tablet using fully kiosk, cant really understand how to make the RTSP stream to pop up on the entire screen when some on hit the button
service: notify.sagi_pc
message: hi
image: /config/www/camsnapshot/cameradoor.png
this is how i set it up and below is the results :
regarding the notify action , the link is to open a link to a dashboard.
I want the front door tablet to popup the RTSP stream on the entire tablet automatically when the button is pressed using the fully kiosk integration . fully kiosk browser integration
There may be better method but I not sure. Kiosks arenât interesting and all tablets are terrible (after nexus 7) so I stop this and look at voice control
I dont think i can help with this. I see Rest api so maybe possible notification can call rest API that make fully kiosk launch to video but you may need to ask other details for making that work
I may look at it in a few days if i get times. Never use it so id have to read on how it works and what is possible
Thank you i know it was a little of topic but thought i give it a go.
Also if you have some inputs regarding the PC notification using hass i would love to hear
Try https link instead of local file
What notification method are you using for PC? Html5 push? What you have looks correct so im guessing the image is not found and just ignored so testing with https link will answer that.
for your 1st question no it doesnât work in a browser (tried both link like above).
regarding the example i just tried it out it also doesnât work for PC.
So if my link is incorrect. any idea what am i doing wrong and what can i change ?
