Simple fix
1.create folder /config/custom_components/notify
2.create file html5v2.py in /config/custom_components/notify
3.add code below to file. All I did was add āimageā to line 95 of standard html5.py
4.change your configuration.yaml or notify.yaml,etc (if you split config files) Push component from html5 to html5v2
5 restart HomeAssistant (all automations will work as is and it will use existing html5_push_registration file)
FYI. for some reason I had to restart my phone to make it work
HTML5 Push Messaging notification service.
For more details about this platform, please refer to the documentation at
https://home-assistant.io/components/notify.html5/
import asyncio
import os
import logging
import json
import time
import datetime
import uuid
import voluptuous as vol
from voluptuous.humanize import humanize_error
from homeassistant.const import (HTTP_BAD_REQUEST, HTTP_INTERNAL_SERVER_ERROR,
HTTP_UNAUTHORIZED, URL_ROOT)
from homeassistant.util import ensure_unique_string
from homeassistant.components.notify import (
ATTR_TARGET, ATTR_TITLE, ATTR_TITLE_DEFAULT, ATTR_DATA,
BaseNotificationService, PLATFORM_SCHEMA)
from homeassistant.components.http import HomeAssistantView
from homeassistant.components.frontend import add_manifest_json_key
from homeassistant.helpers import config_validation as cv
REQUIREMENTS = ['pywebpush==1.1.0', 'PyJWT==1.5.3']
DEPENDENCIES = ['frontend']
_LOGGER = logging.getLogger(__name__)
REGISTRATIONS_FILE = 'html5_push_registrations.conf'
ATTR_GCM_SENDER_ID = 'gcm_sender_id'
ATTR_GCM_API_KEY = 'gcm_api_key'
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Optional(ATTR_GCM_SENDER_ID): cv.string,
vol.Optional(ATTR_GCM_API_KEY): cv.string,
ATTR_SUBSCRIPTION = 'subscription'
ATTR_BROWSER = 'browser'
ATTR_ENDPOINT = 'endpoint'
ATTR_KEYS = 'keys'
ATTR_AUTH = 'auth'
ATTR_P256DH = 'p256dh'
ATTR_EXPIRATIONTIME = 'expirationTime'
ATTR_TAG = 'tag'
ATTR_ACTION = 'action'
ATTR_ACTIONS = 'actions'
ATTR_TYPE = 'type'
ATTR_URL = 'url'
ATTR_JWT = 'jwt'
# The number of days after the moment a notification is sent that a JWT
# is valid.
JWT_VALID_DAYS = 7
KEYS_SCHEMA = vol.All(dict,
vol.Schema({
vol.Required(ATTR_AUTH): cv.string,
vol.Required(ATTR_P256DH): cv.string
SUBSCRIPTION_SCHEMA = vol.All(dict,
vol.Schema({
# pylint: disable=no-value-for-parameter
vol.Required(ATTR_ENDPOINT): vol.Url(),
vol.Required(ATTR_KEYS): KEYS_SCHEMA,
vol.Optional(ATTR_EXPIRATIONTIME):
vol.Any(None, cv.positive_int)
REGISTER_SCHEMA = vol.Schema({
vol.Required(ATTR_SUBSCRIPTION): SUBSCRIPTION_SCHEMA,
vol.Required(ATTR_BROWSER): vol.In(['chrome', 'firefox'])
CALLBACK_EVENT_PAYLOAD_SCHEMA = vol.Schema({
vol.Required(ATTR_TAG): cv.string,
vol.Required(ATTR_TYPE): vol.In(['received', 'clicked', 'closed']),
vol.Required(ATTR_TARGET): cv.string,
vol.Optional(ATTR_ACTION): cv.string,
vol.Optional(ATTR_DATA): dict,
NOTIFY_CALLBACK_EVENT = 'html5_notification'
# Badge and timestamp are Chrome specific (not in official spec)
HTML5_SHOWNOTIFICATION_PARAMETERS = (
'actions', 'badge', 'body', 'dir', 'icon', 'image', 'lang', 'renotify',
'requireInteraction', 'tag', 'timestamp', 'vibrate')
def get_service(hass, config, discovery_info=None):
"""Get the HTML5 push notification service."""
json_path = hass.config.path(REGISTRATIONS_FILE)
registrations = _load_config(json_path)
if registrations is None:
return None
hass.http.register_view(
HTML5PushRegistrationView(registrations, json_path))
hass.http.register_view(HTML5PushCallbackView(registrations))
gcm_api_key = config.get(ATTR_GCM_API_KEY)
gcm_sender_id = config.get(ATTR_GCM_SENDER_ID)
if gcm_sender_id is not None:
add_manifest_json_key(
ATTR_GCM_SENDER_ID, config.get(ATTR_GCM_SENDER_ID))
return HTML5NotificationService(gcm_api_key, registrations, json_path)
def _load_config(filename):
"""Load configuration."""
if not os.path.isfile(filename):
return {}
try:
with open(filename, 'r') as fdesc:
inp = fdesc.read()
# In case empty file
if not inp:
return {}
return json.loads(inp)
except (IOError, ValueError) as error:
_LOGGER.error("Reading config file %s failed: %s", filename, error)
return None
class JSONBytesDecoder(json.JSONEncoder):
"""JSONEncoder to decode bytes objects to unicode."""
# pylint: disable=method-hidden
def default(self, obj):
"""Decode object if it's a bytes object, else defer to baseclass."""
if isinstance(obj, bytes):
return obj.decode()
return json.JSONEncoder.default(self, obj)
def _save_config(filename, config):
"""Save configuration."""
try:
with open(filename, 'w') as fdesc:
fdesc.write(json.dumps(
config, cls=JSONBytesDecoder, indent=4, sort_keys=True))
except (IOError, TypeError) as error:
_LOGGER.error("Saving config file failed: %s", error)
return False
return True
class HTML5PushRegistrationView(HomeAssistantView):
"""Accepts push registrations from a browser."""
url = '/api/notify.html5'
name = 'api:notify.html5'
def __init__(self, registrations, json_path):
"""Init HTML5PushRegistrationView."""
self.registrations = registrations
self.json_path = json_path
@asyncio.coroutine
def post(self, request):
"""Accept the POST request for push registrations from a browser."""
try:
data = yield from request.json()
except ValueError:
return self.json_message('Invalid JSON', HTTP_BAD_REQUEST)
try:
data = REGISTER_SCHEMA(data)
except vol.Invalid as ex:
humanize_error(data, ex), HTTP_BAD_REQUEST)
name = ensure_unique_string('unnamed device', self.registrations)
self.registrations[name] = data
if not _save_config(self.json_path, self.registrations):
'Error saving registration.', HTTP_INTERNAL_SERVER_ERROR)
return self.json_message('Push notification subscriber registered.')
@asyncio.coroutine
def delete(self, request):
"""Delete a registration."""
try:
except ValueError:
subscription = data.get(ATTR_SUBSCRIPTION)
found = None
for key, registration in self.registrations.items():
if registration.get(ATTR_SUBSCRIPTION) == subscription:
found = key
break
if not found:
# If not found, unregistering was already done. Return 200
return self.json_message('Registration not found.')
reg = self.registrations.pop(found)
self.registrations[found] = reg
return self.json_message('Push notification subscriber unregistered.')
class HTML5PushCallbackView(HomeAssistantView):
requires_auth = False
url = '/api/notify.html5/callback'
name = 'api:notify.html5/callback'
def __init__(self, registrations):
"""Init HTML5PushCallbackView."""
def decode_jwt(self, token):
"""Find the registration that signed this JWT and return it."""
import jwt
# 1. Check claims w/o verifying to see if a target is in there.
# 2. If target in claims, attempt to verify against the given name.
# 2a. If decode is successful, return the payload.
# 2b. If decode is unsuccessful, return a 401.
target_check = jwt.decode(token, options={'verify_signature': False})
if target_check[ATTR_TARGET] in self.registrations:
possible_target = self.registrations[target_check[ATTR_TARGET]]
key = possible_target[ATTR_SUBSCRIPTION][ATTR_KEYS][ATTR_AUTH]
try:
return jwt.decode(token, key)
except jwt.exceptions.DecodeError:
pass
return self.json_message('No target found in JWT',
status_code=HTTP_UNAUTHORIZED)
# The following is based on code from Auth0
# https://auth0.com/docs/quickstart/backend/python
def check_authorization_header(self, request):
"""Check the authorization header."""
import jwt
auth = request.headers.get('Authorization', None)
if not auth:
return self.json_message('Authorization header is expected',
parts = auth.split()
if parts[0].lower() != 'bearer':
return self.json_message('Authorization header must '
'start with Bearer',
elif len(parts) != 2:
'be Bearer token',
token = parts[1]
try:
payload = self.decode_jwt(token)
except jwt.exceptions.InvalidTokenError:
return self.json_message('token is invalid',
return payload
@asyncio.coroutine
"""Accept the POST request for push registrations event callback."""
auth_check = self.check_authorization_header(request)
if not isinstance(auth_check, dict):
return auth_check
try:
except ValueError:
event_payload = {
ATTR_TAG: data.get(ATTR_TAG),
ATTR_TYPE: data[ATTR_TYPE],
ATTR_TARGET: auth_check[ATTR_TARGET],
if data.get(ATTR_ACTION) is not None:
event_payload[ATTR_ACTION] = data.get(ATTR_ACTION)
if data.get(ATTR_DATA) is not None:
event_payload[ATTR_DATA] = data.get(ATTR_DATA)
try:
event_payload = CALLBACK_EVENT_PAYLOAD_SCHEMA(event_payload)
_LOGGER.warning("Callback event payload is not valid: %s",
humanize_error(event_payload, ex))
event_name = '{}.{}'.format(NOTIFY_CALLBACK_EVENT,
event_payload[ATTR_TYPE])
request.app['hass'].bus.fire(event_name, event_payload)
return self.json({'status': 'ok',
'event': event_payload[ATTR_TYPE]})
class HTML5NotificationService(BaseNotificationService):
"""Implement the notification service for HTML5."""
def __init__(self, gcm_key, registrations, json_path):
"""Initialize the service."""
self._gcm_key = gcm_key
self.registrations_json_path = json_path
@property
def targets(self):
"""Return a dictionary of registered targets."""
targets = {}
for registration in self.registrations:
targets[registration] = registration
return targets
def send_message(self, message="", **kwargs):
"""Send a message to a user."""
import jwt
from pywebpush import WebPusher
timestamp = int(time.time())
tag = str(uuid.uuid4())
payload = {
'badge': '/static/images/notification-badge.png',
'body': message,
ATTR_DATA: {},
'icon': '/static/icons/favicon-192x192.png',
ATTR_TAG: tag,
'timestamp': (timestamp*1000), # Javascript ms since epoch
ATTR_TITLE: kwargs.get(ATTR_TITLE, ATTR_TITLE_DEFAULT)
data = kwargs.get(ATTR_DATA)
if data:
# Pick out fields that should go into the notification directly vs
# into the notification data dictionary.
data_tmp = {}
for key, val in data.items():
if key in HTML5_SHOWNOTIFICATION_PARAMETERS:
payload[key] = val
else:
data_tmp[key] = val
payload[ATTR_DATA] = data_tmp
if (payload[ATTR_DATA].get(ATTR_URL) is None and
payload.get(ATTR_ACTIONS) is None):
payload[ATTR_DATA][ATTR_URL] = URL_ROOT
targets = kwargs.get(ATTR_TARGET)
if not targets:
targets = self.registrations.keys()
for target in list(targets):
info = self.registrations.get(target)
if info is None:
_LOGGER.error("%s is not a valid HTML5 push notification"
" target", target)
continue
jwt_exp = (datetime.datetime.fromtimestamp(timestamp) +
datetime.timedelta(days=JWT_VALID_DAYS))
jwt_secret = info[ATTR_SUBSCRIPTION][ATTR_KEYS][ATTR_AUTH]
jwt_claims = {'exp': jwt_exp, 'nbf': timestamp,
'iat': timestamp, ATTR_TARGET: target,
ATTR_TAG: payload[ATTR_TAG]}
jwt_token = jwt.encode(jwt_claims, jwt_secret).decode('utf-8')
payload[ATTR_DATA][ATTR_JWT] = jwt_token
response = WebPusher(info[ATTR_SUBSCRIPTION]).send(
json.dumps(payload), gcm_key=self._gcm_key, ttl='86400')
# pylint: disable=no-member
if response.status_code == 410:
_LOGGER.info("Notification channel has expired")
reg = self.registrations.pop(target)
if not _save_config(self.registrations_json_path,
self.registrations[target] = reg
_LOGGER.error("Error saving registration.")
else:
_LOGGER.info("Configuration saved")
