I just bought an Amcrest ASH43-W camera as my first RTSP enable camera and am having a lot of trouble setting it up to just view the live stream through home assistant. So after ~2, 5hr nights of trying to get this to work and reading various posts, I figured I’d reach out… Below are the configuration.yaml entries I have tried:
ffmpeg:
ffmpeg_bin: /usr/bin/ffmpeg
stream:
#setup 1
camera:
- platform: ffmpeg
input: -rtsp_transport tcp -i rtsp://user:pass@IPaddress:554/cam/realmonitor?channel=1&subtype=0&authbasic=64
#setup 2
camera:
- platform: generic
still_image_url: ?????????????
stream_source: rtsp://user:pass@IPaddress:554/cam/realmonitor?channel=1&subtype=0&authbasic=64
username: !secret amcrest_device_username
password: !secret amcrest_password
#setup 3
amcrest:
- host: IPaddress
port: 554 (with and without this)
stream_source: rtsp
binary_sensors:
- motion_detected
- online
In generic camera setup and ffmpeg camera setup, a camera entity is created, but when I click the entity to view the live feed I just get a quick loading circle and then gray.
In the amcrest integration setup, the sensors get created (not functional obviously), but the camera entity does not get created.
with the ffmpeg camera setup there doesn’t seem to be an error assossiated, but below is the error I am getting with amcrest and generic camera setup (2 and 3) seems similar to this post for a different camera ([Can not get Amcrest IP2M-841B to work - #5 by carbuthn]):
Logger: homeassistant.components.camera
Source: components/amcrest/__init__.py:177
Integration: Camera (documentation, issues)
First occurred: 12:37:50 AM (1 occurrences)
Last logged: 12:37:50 AM
Error while setting up amcrest platform for camera
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 445, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 440, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.9/http/client.py", line 1371, in getresponse
response.begin()
File "/usr/local/lib/python3.9/http/client.py", line 319, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.9/http/client.py", line 280, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.9/socket.py", line 704, in readinto
return self._sock.recv_into(b)
socket.timeout: timed out
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py", line 532, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.9/site-packages/urllib3/packages/six.py", line 770, in reraise
raise value
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 447, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 336, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='192.168.1.213', port=80): Read timed out. (read timeout=6.05)
File "/usr/local/lib/python3.9/site-packages/amcrest/http.py", line 273, in _command
resp = session.get(
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 555, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.1.213', port=80): Read timed out. (read timeout=6.05)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 249, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/amcrest/camera.py", line 144, in async_setup_platform
serial_number = await hass.async_add_executor_job(lambda: device.api.serial_number) # type: ignore[no-any-return]
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/amcrest/camera.py", line 144, in <lambda>
File "/usr/local/lib/python3.9/site-packages/amcrest/system.py", line 130, in serial_number
return pretty(self._magic_box("getSerialNo"))
File "/usr/local/lib/python3.9/site-packages/amcrest/http.py", line 461, in _magic_box
ret = self.command(f"magicBox.cgi?action={action}")
File "/usr/src/homeassistant/homeassistant/components/amcrest/__init__.py", line 177, in command
ret = super().command(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/amcrest/http.py", line 221, in command
self._generate_token()
File "/usr/local/lib/python3.9/site-packages/amcrest/http.py", line 118, in _generate_token
resp = self._command(cmd).content.decode()
File "/usr/local/lib/python3.9/site-packages/amcrest/http.py", line 295, in _command
raise CommError(error) from error
amcrest.exceptions.CommError: HTTPConnectionPool(host='192.168.1.213', port=80): Read timed out. (read timeout=6.05)
The RTSP stream link works fine in VLC media player. I have tried everything that I can find for amcrest for the still_image_url, but nothing works in a browser or anything (the ‘amcrest smart home’ devices don’t seem to support http for this still image).
I understand that the amcrest integration may not support this camera, but I feel like I should be able to atleast get a live feed of the camera via RTSP using one of these setups.
Any help would be much appreciated.
Update:
I also tried to setup this camera with Frigate with default ffmeg args as well as all the ones described for camera specific configurations (Camera Specific Configurations | Frigate). All of them gave green screen in Frigate with ffmpeg broken image errors, except for the MJPEG Camera Configurations. However it was VERY choppy (mostly showed gray), but I would catch glimpses of the video feed, and didn’t show errors in the frigate logs atleast.
Anyways, I am going to just return this camera, because it is not worth the headache it seems and I was able to setup the reolink RLC-410 without any issues (as generic camera and in Frigate).
