Amcrest Camera not working on hass.io
I have a pretty simple amcrest that was working at one point (and is working via the direct url to the camera). The only related errors I see in the log are:
2020-02-18 22:17:30 ERROR (MainThread) [homeassistant.components.camera] Error requesting stream: Camera is off
2020-02-18 22:17:30 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.30.33.4
Any idea how I can debug?
The error looks like invalid username/password.
Include your configuration so we can see. I have an Amcrest DVR and mine work but you have to pass the username/password in the rtsp link.
-Tim
Configuration is pretty simple:
amcrest: !include config/amcrest.yaml
Then in amcrest.yaml
  - host: 192.168.1.17
    username: admin
    password: MYADMINPASS
This is mine, I have the user & pass in the rtsp config:
camera:
    - platform: ffmpeg
      input: !secret DVR_Channel03
      extra_arguments: '-q:v 1 -r 25 -vf "scale=800:600"'
DVR_Channel03: rtsp://user:pass@DVRIP:554/cam/realmonitor?channel=3&subtype=0
Is the camera on? (Both “physically”, and is the state of the camera entity not idle?) What does its state and attributes look like?
You can get a lot more detail about what’s going on by adding this (or similar) to your config:
logger:
  default: info
  logs:
    amcrest: debug
    homeassistant.components.amcrest: debug
Restart and then look in home-assistant.log. I’d be happy to help interpret the details.
