PanMat
(Pankaj)
August 11, 2020, 4:04am
1
So I have following code working fine when placed in configuration.yaml file.
amcrest:
- host: !secret amcrest_2_ip
username: !secret amcrest_username
password: !secret amcrest_password
binary_sensors:
- motion_detected
- online
sensors:
- sdcard
camera:
- platform: amcrest
But I want to keep configuration file short and clean and move this code to another file under “cameras/amcrest.yaml”.
So I changed the configuration.yaml file to include:
camera: !include cameras/amcrest.yaml
(–> line 14 in the code)
And placed following code under “cameras/amcrest.yaml”
camera amcrest-2:
binary_sensors:
- motion_detected
- online
sensors:
- sdcard
camera:
- platform: amcrest
But the configuration is coming as invalid with following error:
Invalid config for [camera]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 14).
Any pointers how to fix the code for “cameras/amcrest.yaml”?
Thanks,
Pankaj
atomicpapa
(Glenn Morrison)
August 11, 2020, 4:46am
2
The only thing that should be in that file, since you are including it from
camera:
is
- platform: amcrest
You can do this 2 different ways
#1 ) split these up by having 2 lines in your configuration.yaml
amcrest: !include amcrest.yaml
camera: !include camera.yaml
amcrest.yaml
would include
binary_sensors:
- motion_detected
- online
sensors:
- sdcard
and camera.yaml
would merely have
- platform: amcrest
#2 ) If you are already using Packages , just add a new file called amcrest.yaml
in your packages folder. If you are not using packages, read up at that link and it will guide you through setting it up. Packages is the way to go if you want to reduce the size of configuration.yaml
if you go the packages route, the amcrest.yaml
file would consist of
amcrest:
binary_sensors:
- motion_detected
- online
sensors:
- sdcard
camera:
- platform: amcrest
PanMat
(Pankaj)
August 11, 2020, 5:18am
3
Hi Glenn,
You are spot on, I added amcrest.yaml and camera.yaml and the camera started working
But now I have another problem, I also have a Bedser camera and added “bedser.yaml” file to cameras folder, the Bedser camera is working on standalone basis.
To make HA read all the camera files, I modified “configuration.yaml” as follows:
#camera: !include cameras/bedser.yaml
amcrest: !include cameras/amcrest.yaml
#camera: !include cameras/camera.yaml
camera: !include_dir_merge_named cameras/
Here is the code under “Bedser.yaml”:
- platform: generic
username: !secret bedeser_2_username
password: !secret bedser_2_password
still_image_url: !secret bedser_2_still_url
stream_source: !secret bedser_2_stream_source
So the file is not giving any “invalid” syntax error but the Bedser camera is not showing up in entities.
Any pointers why it is not loading?
Thanks and appreciate your help!
Pankaj
atomicpapa
(Glenn Morrison)
August 11, 2020, 6:03am
4
I would have just added the bedser info to the camera.yaml file you already had and not made a directory for each camera. Mine looks like this…
- platform: nwsradar
station: ewx
style: Enhanced
frames: 8 # Optional
- platform: ffmpeg
name: Wyze Cam 1
input: !secret wyzecam1
- platform: ffmpeg
name: Wyze Cam 2
input: !secret wyzecam2
- platform: ffmpeg
name: Wyze Cam 3
input: !secret wyzecam3
# - platform: ffmpeg
# name: Front Door Cam
# input: !secret front_cam
- platform: mjpeg
still_image_url: "http://192.168.1.17/webcam/?action=snapshot"
mjpeg_url: "http://192.168.1.17/webcam/?action=stream"
- platform: local_file
file_path: /local/mail_and_packages/mail_today.gif
- platform: generic
still_image_url: !secret cam_102_url
stream_source: !secret cam_102_url
- platform: mjpeg
mjpeg_url: !secret cam_105_url
PanMat
(Pankaj)
August 11, 2020, 11:41pm
5
Thanks Glenn…that’s two for two
Appreciate the help, both cameras are working like a charm!
That hasn’t been necessary for a long time. You can just delete it. You only need the stuff under amcrest
PanMat
(Pankaj)
August 12, 2020, 10:49pm
7
Thanks Phil.
I moved the Bedser camera to its own file and deleted “camera.yaml”…this configuration also worked with both cameras!
Good to find multiple ways of using HA
