I can only get 1 of the 4 to work, which is the last one in the configuration. I’ve read the various posts concerning this issue and I can’t find a solution.
Has anyone had similar problems and were you able to solve them?
Mine are set up similar to yours (Poe cams connected to nvr). I couldn’t get mine to work when I set it up like that either. I ended up using the ffmpeg config as follows: (forgive the formatting. I’m away and can only do this on my phone)
