Amcrest DVR + Hass RTSP
I am trying to set up the RTSP feed. I have tested the feed in VLC and it works fine. I added a picture entity card - I am doing something wrong but not sure what. Thoughts?
Config.yaml
amcrest:
  - host: 192.168.1.108
    resolution: low
    username: <user>
    password: <pass>
    port: 554
    stream_source: rtsp
ui.yaml
- type: picture-entity
  entity: camera.cam_test
  camera_view: live
Getting this on the dashboard
One of the differences I see is that there are parameters on the URL when it is added as generic. When I used the above implementation I don’t know how to select the camera since I have 4 connected. These are the parameters
/cam/realmonitor?channel=4&subtype=0
Option two - platform generic
Just in case that the above is for IP cameras only. I added the stream_source and the login info in the URI. Those are just coming blank. Just to reiterate - the streams / thumbnails are working via browser and VLC.
Hi! Have you managed? I’m trying to accomplish the same.
