Have you tried to put both into the main configuration.yaml file?
It might have to do with the way you’re inserting the two comeras into the armcrest.yaml file…
That’s my entry in configuration.yaml:
# Showing picture from all Cameras
camera: !include cameras.yaml
And this is how I set up the first two cameras in the cameras.yaml file:
Nov 14 15:56:41 homeassistant hass[8517]: #033[31m2017-11-14 15:56:41 ERROR (MainThread) [homeassistant.setup] Error during setup of component amcrest#033[0m
Nov 14 15:56:41 homeassistant hass[8517]: Traceback (most recent call last):
Nov 14 15:56:41 homeassistant hass[8517]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 194, in _async_setup_component
Nov 14 15:56:41 homeassistant hass[8517]: component.setup, hass, processed_config)
Nov 14 15:56:41 homeassistant hass[8517]: File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
Nov 14 15:56:41 homeassistant hass[8517]: yield self # This tells Task to wait for completion.
Nov 14 15:56:41 homeassistant hass[8517]: File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
Nov 14 15:56:41 homeassistant hass[8517]: future.result()
Nov 14 15:56:41 homeassistant hass[8517]: File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
Nov 14 15:56:41 homeassistant hass[8517]: raise self._exception
Nov 14 15:56:41 homeassistant hass[8517]: File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
Nov 14 15:56:41 homeassistant hass[8517]: result = self.fn(*self.args, **self.kwargs)
Nov 14 15:56:41 homeassistant hass[8517]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/amcrest.py", line 92, in setup
Nov 14 15:56:41 homeassistant hass[8517]: amcrest_cams = config[DOMAIN]
Nov 14 15:56:41 homeassistant hass[8517]: KeyError: 'amcrest'#033[0m
Nov 14 15:56:41 homeassistant hass[8517]: #033[31m2017-11-14 15:56:41 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of camera.amcrest. Setup failed for dependencies: amcrest#033[0m
Nov 14 15:56:41 homeassistant hass[8517]: #033[31m2017-11-14 15:56:41 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform camera.amcrest: Could not setup all dependencies.#033[0m
Sorry, @anon91811138 - that’s all the suggestions I had.
As you can see from my example, I’m working with Foscam, not Amcrest, and looking at the component details at https://home-assistant.io/components/amcrest/ my suggestion was wrong in the first place.
I have two possible issues, that have happened to me.
The first one, fits right in with your issue. DO NOT “CUT & PASTE” then changed the unique info. CUTTING & PASTING, seems to introduce “BAD” characters, I did this and it caused me issues. So I typed in, ALL the config info, character by character, and All 4 of my Amcrest Cams now work. I still get WARNINGS, in my HA Log, which leads to my;
Second Issue, POOR Wifi signal, The Camera that is the Furthest from the Router is dropping Frames(snapshots). I can see this, when I ping the IP of the 4th Cam for a long period of time, and get a lot of ridiculous Ping times. I mean ping times of 4523ms(4-5 seconds). When I remove the 4th Cam from the HA Config, the amount of Warnings, drops drastically.
I am still battling the WiFi signal issue, something near my house,(maybe inside) is interfering with my WiFi signal.
Note: I am doing my Cam config, in the Configuration.yaml, and I also commented out the following;
And even with a Interval of 1 second, the will take 3 seconds or more to update to the next frame(snapshot). And I strongly believe, this is because of the WiFi Signal issue.
I originally thought a ping time might be the issue as the cameras in question do reside quite a distance from the Router. However as part of testing, I started by directly connecting with a wired connection to each one. cable length under 6 feet.
Same issue. So it appears in my case its a software issue. As for stray characters, I used Atom to check spacing and text. All lined up, no extra characters.
All my text, lined up properly, too. But, there was a character that did not belong. One of the issues that I do wrong, a lot, is using an “UPPERCASE LETTERS” in the wrong places. Also, don’t forget, there are “Control Characters” that will show as a “Space character”…
I may have actually gotten it to work…sorta. I played around with the bitrate/framrate settings. On the initial page load of the image it only updates every 5-10 seconds. But If I click on it and it loads the popup, it streams the image, but at very low quality.
I’ve started to slowing adjust the settings to see how good an image I can get before it errors out. I’ll let you know my final settings once I get it as good as possible.
does anybody had luck with the amcrest component using multiple cameras?? it seems to be broken on the last 2 updates, i think it was broken on 0.58 or 0.59.
i have 2 cameras and this is my config
host: 192.168.10.45
username: user
password: pass
stream_source: rtsp
resolution: high
host: 192.168.10.55
username: user
password: pass
stream_source: rtsp
resolution: high
sometimes both cameras work, sometimes cam1 works and sometimes cam2 works.
my theory is for some reason HASS is opening too many connections to the cameras but it never closes the TCP session, collapsing the camera resourses
check this output ( the output is actually showing more connections i just trimmed )
