Been running Home Assistant on Raspberry Pi’s for years and a Blue for a while but looking to upgrade the horsepower. Does anyone know if Home Assistant and Frigate Add On will run on a HP Mini PC Model 705 G3 running an AMD Pro A12 9800E? I’m thinking the built in Radeon R7 graphics will help with the object detection in Frigate. My other choice is a Lenovo ThinkCentre M710q running a i5-7500T. Thanks.
That won’t help with object detection, it’ll only help with hardware decoding the streams.
As far as if it will work, you just need to make sure the CPU supports AVX instructions
Thanks for the reply. I more I research the 9800E the less ‘shine’ it has as it seems it didn’t impress many folks, so I think I’ll go with the 7500T based system.
