it seems that EKD removed or changed the path for the rest api wit the latest firmware upgrade from http://myIP/rest/items/xxx
Example:(http://myIP/rest/items/sajhybrid_battery_94_HST2103J2306E04770_battery_stateOfCharge) to something different.
My current integration does not work anymore. Does anybody have the new path to the rest information.
running version of Ampere.IQ (kiwigrid) is: 10.26.24.4
hey,
I also just noticed that the REST endpoint has vanished. Have you made any progress?
thanks.
depending on the Inverter you have, you could use communication over modbus instead of REST.
Some of the inverter/battery inverter combos EKD uses are just rebranded SAJ devices. The Ampere.Storage Pro is an example.
There is an integration available for SAJ modbus devices called SAJ H2 Modbus. When setting that up you need to put in the IP adress of the Ampere.Storage Pro and not the IP adress of the smartbox where the REST API was running on.
Sadly this doesn’t give you all the data if you have additonal inverters from Solarmax like I do.
yeah thanks that’s what I’ve been trying for the last 3h, but I’m not getting all the values (like grid import/export), and I can’t find the issue
