"Ampio" integration
Hi Everyone!
I’m trying to revive an old integration, so this is my forked repo: https://github.com/pszypowicz/ampio-hacc
I setup the hassfest pipeline and fixed the obvious errors.
I added it via HACS wit a direct link to repository, and then I installed it in a HACS under “Integration” card. Home Assistant does not produce any errors anymore. But I still cannot enable it from the “integrations” tab in HA. Search does not return anything for an “Ampio” keyword.
Could someone point me in the right direction with a debugging of a custom component? I would appreciate any help.
Please double check if integration was supposed to be setup using config flow (ui) or YAML. Only ui based integrations would be visible there.
Edit: apparently it should work with config flow. Check the error logs please
For whatever reason, after “one again” reboot of the whole host, the integration got detected!
btw I turned on the “debug” logs and still could not found anything helpful there.
Thank you @anon63427907 for your willingness to help.
Hi Przemek,
Have you integrated AMPIO with HA finally? What modules are available for HA integration?
