I am trying to get AMR2MQTT to work. I have configured AMR2MQTT and Mosquitto Broker. I initially had trouble with AMR2MQTT giving a “connection refused” error. But I believe I resolved that successfully by correcting the port number. AMR2MQTT now connects to 10.1.1.114:1884 (which is local host, i had some issues getting 127.0.0.1 to work).
AMR2MQTT appears to be seeing my meters based on the log below:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/00-banner.sh
Add-on: AMR2MQTT
AMR2MQTT for Home Assistant
Add-on version: 2.1.2
You are running the latest version of this add-on.
System: Home Assistant OS 10.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.5.3
Home Assistant Supervisor: 2023.04.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
Log level is set to DEBUG
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/02-set-timezone.sh
[20:37:31] INFO: Configuring timezone
cont-init: info: /etc/cont-init.d/02-set-timezone.sh exited 0
cont-init: info: running /etc/cont-init.d/30-config.sh
[20:37:31] DEBUG: Validate config and look for suggestions
[20:37:33] INFO: Ensure MQTT broker is reachable at 10.1.1.114:1884 (60s timeout)
cont-init: info: /etc/cont-init.d/30-config.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun amr2mqtt (no readiness notification)
services-up: info: copying legacy longrun rtl_tcp (no readiness notification)
s6-rc: info: service legacy-services successfully started
[20:37:33] DEBUG: Setting MQTT details...
[20:37:33] INFO: Starting rtl_tcp daemon...
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
Tuned to 100000000 Hz.
[20:37:35] INFO: Log level set to DEBUG
[20:37:35] INFO: Waiting for rtl_tcp...
Allocating 15 zero-copy buffers
[20:37:35] INFO: Handing over control to AMR2MQTT...
Signal caught, exiting!
INFO:root:Starting rtlamr
INFO:root:Connecting to MQTT broker at 10.1.1.114:1884
20:37:36.686151 decode.go:45: CenterFreq: 912600155
20:37:36.687103 decode.go:46: SampleRate: 2359296
20:37:36.687318 decode.go:47: DataRate: 32768
20:37:36.687495 decode.go:48: ChipLength: 72
20:37:36.687690 decode.go:49: PreambleSymbols: 32
20:37:36.687874 decode.go:50: PreambleLength: 4608
20:37:36.688071 decode.go:51: PacketSymbols: 128
20:37:36.688249 decode.go:52: PacketLength: 18432
20:37:36.688451 decode.go:59: Protocols: r900,scm+
20:37:36.688572 decode.go:60: Preambles: 00000000000000001110010101100100,0001011010100011
20:37:36.688832 main.go:111: GainCount: 29
DEBUG:root:Meter: 91211181, MsgType: scm+, Reading: {"FrameSync": 5795, "ProtocolID": 30, "EndpointType": 156, "EndpointID": 91211181, "Consumption": 4408320.0, "Tamper": 5648, "PacketCRC": 21102}
DEBUG:root:Meter: 1568947908, MsgType: r900, Reading: {"ID": 1568947908, "Unkn1": 163, "NoUse": 36, "BackFlow": 0, "Consumption": 255575.0, "Unkn3": 0, "Leak": 0, "LeakNow": 0}
DEBUG:root:Meter: 1568515126, MsgType: r900, Reading: {"ID": 1568515126, "Unkn1": 163, "NoUse": 32, "BackFlow": 0, "Consumption": 192065.0, "Unkn3": 0, "Leak": 0, "LeakNow": 0}
According to the documentation, by default the meter consumption is published to amr2mqtt/{meter_ID}. I have attempted to override this with mqtt_base topic, with it set to amr2mqtt. This did not produce any changes.
I installed MQTT explorer on my Win 10 computer to attempt to view the topics and their values. However, the only one that displays is $SYS. I do not see any for “amr2mqtt.”
AMR2MQTT also says that it can be set to auto-publish the meter. I have this turned on, but nothing has automatically been added.
Any help you can provide would be great!
Thanks,
Dallas
