Hi. Is any chance to release new addon with new ebusd 22.3 ?
Hello
i just buy an ebusd wifi adapter, (EBUS to WiFi adapter by Daniel Kucera's store) and i want to launch the ebusd addon to follow the potentiometer adjustment documentation. (6. Hardware · john30/ebusd Wiki · GitHub)
i tried to edit the configuration like this but it doesn’t work any idea ?
scanconfig: true
loglevel_all: debug
mqtttopic: ebusd
mqttint: /etc/ebusd/mqtt-hassio.cfg
mqttjson: true
network_device: udp:192.168.10.32:9999
latency: 10
commandline_options: '-f -c /tmp --logareas bus --loglevel info --lograwdata=bytes'
and the logs tell me
> ebusd --foreground --mqtthost=core-mosquitto --mqttport=1883 --mqttuser=addons --mqttpass=wish4apoCh3aiph1oobol8dahdohx9oozoeDap6yee4athei4Aevee5uxohphaih --scanconfig --mqttjson --latency=10 --mqttint=/etc/ebusd/mqtt-hassio.cfg --mqtttopic=ebusd --device=udp:192.168.10.32:9999 --log=all:debug -f -c /tmp --logareas bus --loglevel info --lograwdata=bytes
ebusd: invalid logareas (combined with log)
Did you read the ebusd log output…
Remove this from your command line options:
This option is also an advanced option that you shouldn’t need unless you have a specific reason so can be removed:
--lograwdata=bytes
Hello
When i remove --logareas bus --loglevel info, i don’t have any error, but i don’t see message from the bus in the log to manage the adjustment of the potentiometer.
because i don’t see any equipement on the bus or any bus log at all.
I have two questions:
- Which is the URL to the newest add-on repo? I lost track of the thread regarding this.
- Is it possible to use a local config file? I have a ebusd device config that is not in the official configuration repo.
Thanks a lot
Jan
Ebusd is latest stable release. Ebusd-edge compiles latest sources from GitHub
Yes, there is an option for that. Read the docs
Thanks!
Today I moved from my docker-compose setup to the add-on. Without a problem!
Works great with my Vaillant recoVAIR VAR 260/4.
Hi everyone! I am going to attempt to integrate some devices that have ebus into home assistant, namely my mechanical ventation with heat recuperator (WOLF CLW-300) and my all-in-one heatpump (Saunier Duval genia set 8).
For now I’ve run two-wire cable from the Wolf ventilation to the raspberry where I have my HA running. I few months back I bought the ebuzzz adapter (eBUS USB Adapter (eBuzzz adapter) from FoxRom Store (from fromeijn.nl) on Tindie) since the ebus adapter v3 that it’s kind of “official” was out of stock and the creator didn’t anticipate stock coming back soon. Seems that there’s stock now.
I have a couple questions that might be basic, but here they go:
- Can I connect two ebus devices (heatpump and heat recuperator) to the same adapter?
- If as I imagine I’ll need a second adapter, will the home assistant add-on be able to control two devices using two adapter?
Thanks. Hopefully tonight I’ll try to connect the wires for real.
I seems to kind of work, but it doesn’t do much/anything. It seems to know that there’s a Wolf device connected, but the logs show a lot of messages about unknown commands and the only MQTT messages being sent are generic messages about the status, uptime and similar stuff about ebusd itself.
These are the relevant logs:
2022-06-20 23:10:45.356 [bus notice] bus started with own address 31/36
2022-06-20 23:10:45.399 [bus notice] signal acquired
2022-06-20 23:10:45.859 [mqtt notice] connection established
2022-06-20 23:10:48.170 [bus notice] new master 37, master count 2
2022-06-20 23:10:52.370 [bus notice] new master f1, master count 3
2022-06-20 23:10:52.371 [update notice] received unknown BC cmd: f1fe0800080080333380000000
2022-06-20 23:10:55.533 [bus notice] scan 3c: ;ENCON; ;-;-
2022-06-20 23:10:55.533 [update notice] store 3c ident: done
2022-06-20 23:10:55.533 [update notice] sent scan-read scan.3c QQ=31: ENCON; ;-;-
2022-06-20 23:10:55.954 [main error] unable to load scan config 3c: list files in encon ERR: element not found
2022-06-20 23:10:55.954 [main error] scan config 3c: ERR: element not found
2022-06-20 23:10:58.090 [main error] scan config f6: ERR: read timeout
2022-06-20 23:11:00.703 [bus notice] new master 30, master count 4
2022-06-20 23:11:00.704 [update notice] received update-read broadcast datetime QQ=30: -;00:36:10;-.-.-
2022-06-20 23:11:10.265 [bus notice] scan 35: ;Wolf; 8;0110;0000
2022-06-20 23:11:10.265 [update notice] store 35 ident: done
2022-06-20 23:11:10.265 [update notice] sent scan-read scan.35 QQ=31: Wolf; 8;0110;0000
2022-06-20 23:11:10.564 [main error] unable to load scan config 35: list files in wolf ERR: element not found
2022-06-20 23:11:10.564 [main error] scan config 35: ERR: element not found
2022-06-20 23:11:17.072 [update notice] received unknown MS cmd: 303c40a106000100010000 / 023000
2022-06-20 23:11:20.122 [update notice] received unknown MS cmd: 303c40220101 / 020001
2022-06-20 23:11:22.370 [update notice] received unknown BC cmd: f1fe0800080080333380000000
2022-06-20 23:11:52.393 [update notice] received unknown BC cmd: f1fe0800080080333380000000
2022-06-20 23:12:00.691 [update notice] received update-read broadcast datetime QQ=30: -;00:37:10;-.-.-
2022-06-20 23:12:16.094 [update notice] received unknown MS cmd: 303c40a106000100010000 / 023000
2022-06-20 23:12:19.122 [update notice] received unknown MS cmd: 303c40220101 / 020001
2022-06-20 23:12:22.433 [update notice] received unknown BC cmd: f1fe0800080080333380000000
What can be happening? Maybe ebusd doesn’t know how to understand messages sent by the Wolf CWL-300?
Hi. ANybody can telle me how on autodiscovery mqtt use this untieties from ebusd to create example thermostat with controll temperature ? How set temp ? I can not do it… not working for me as works for old config without autodiscovery…
Is aby chance to upgrade ebusd addon to version 22.4 because it support high speed serial.
22.4 is not released yet. If you want to use bleeding edge code use ebusd-edge addon. This builds ebusd locally from the latest sources
But on page where is firmware for ebusd adapter write about 22.4
Hi. Good feature will be that password in addon to MQTT should be hide as stars… Now is still show.
Look on addon samba, it hass password hide and show as points and we can show it by clikc on eye on the right.
Good suggestion, please do a pull request
I dont how do it. I am not developer
