You won’t be able to get the video into HA short of using a video capture device to digitize it (it would be cheaper to buy a digital doorbell system) but if you wanted to integrate the lock control you could use an ESP (running ESPhome is best) and a relay to run in parallel to the doorbells lock relay.
That’s as good as you will get short of cracking it open and wiring things inside to potentially interface to the button. (could wire that to the same ESP as an input) At this point you may as well have thrown the ancient thing in the bin and bought something from this decade.
