I want to create an automation to switch off the heating furnace (switch.verwarming_brander) when ALL of the radiators (also switches because they all have a solenoid valve) are OFF
I can’t use the triggers because then it will switch off when 1 of the radiators switches off, it should wait untill the LAST one switches off
The multiple triggers use “OR” function, but I need “AND”
It should only switch off the heater when the last radiator switches off.
How should I do this ?
I already have an automation for switching ON the burner, but that’s easy because there does need the “OR” function on the triggers : If any radiator switches on, the burner should switch on … easy peasy … but for switching OFF … ???
I thought of putting all the radiators as trigger going from “on” to “off” and then adding all the radiators again as condition being “off” … but I think that would create a problem on the last one, because at the moment of the trigger the condition is still “on”, so it won’t pass the condition at that moment … but because of it switching off there won’t be any other trigger to turn the furnace off … hmmmmmm
Create a group containing all the radiator switches. Use the group in a State Trigger because the group will report off only when all radiators are off.
edit: all of the other posts have covered it, my post is essentially superfluous. I especially like 123’s idea.
This is easy. Just put all radiators as a trigger and all radiators as a condition. It will only fire once the last one goes off.
like this: (bad syntax as I am doing this by hand)
- entity: heater.heater1
to_state: off
- entity: heater.heater2
to_state: off
conditions:
state: off
state: off
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic is resolved. This helps other users find answers to similar questions.
For more information, refer to guideline 21 in the FAQ.
