I’m looking to create a flow to do the following and can’t figure it out.
- Light #1 has been on for 5 minutes (got this part).
- Wait Until Light #2 has been on for 5 minutes. (this is the part I can’t figure out).
If you post what you have, it makes it easier for people to help.
not sure this is exactly what you’re after but I hope it helps you somehow
[{"id":"6917641c.f8f94c","type":"server-state-changed","z":"74e4c309.282f6c","name":"Light 1 on for 5 minutes?","server":"9405c3fe.d0a6c","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"light.light_1","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"5","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":270,"y":300,"wires":[["cfff401e.8d638"],[]]},{"id":"cfff401e.8d638","type":"ha-wait-until","z":"74e4c309.282f6c","name":"wailt until it's been on for 5 minutes","server":"9405c3fe.d0a6c","outputs":2,"entityId":"light.light_2","entityIdFilterType":"exact","property":"state","comparator":"is","value":"off","valueType":"str","timeout":"5","timeoutType":"num","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":550,"y":300,"wires":[[],["5abe49ed.ed9ac8"]]},{"id":"5abe49ed.ed9ac8","type":"debug","z":"74e4c309.282f6c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":820,"y":340,"wires":[]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","addon":true}]
if the previous one doesn’t fit your needs because the flows stops if light 2 is off, this one will do it.
Note that in both cases the flow continues through the timeout output of the later wait until node.
[{"id":"b1884ae7.ac07e8","type":"server-state-changed","z":"74e4c309.282f6c","name":"Light 1 on for 5 minutes?","server":"9405c3fe.d0a6c","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"light.light_1","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"5","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":230,"y":320,"wires":[["fae27748.6e9438"],[]]},{"id":"5af02f18.53401","type":"ha-wait-until","z":"74e4c309.282f6c","name":"wailt until it's been on for 5 minutes","server":"9405c3fe.d0a6c","outputs":2,"entityId":"light.light_2","entityIdFilterType":"exact","property":"state","comparator":"is","value":"off","valueType":"str","timeout":"5","timeoutType":"num","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":680,"y":320,"wires":[[],["b648084e.0c1ef8"]]},{"id":"b648084e.0c1ef8","type":"debug","z":"74e4c309.282f6c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":950,"y":360,"wires":[]},{"id":"fae27748.6e9438","type":"ha-wait-until","z":"74e4c309.282f6c","name":"wailt until it's on","server":"9405c3fe.d0a6c","outputs":1,"entityId":"light.light_2","entityIdFilterType":"exact","property":"state","comparator":"is","value":"on","valueType":"str","timeout":0,"timeoutType":"num","timeoutUnits":"seconds","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":440,"y":320,"wires":[["5af02f18.53401"]]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","addon":true}]`
