Andoid APP can't connect from lokal WLAN
Good Morning.
I’m using duckdns for external communication.
Alexa und Cloud and some other Integrations are normal running.
My Settings in hassio are:
external: https://url.duckdns.org/
internal: https://192.168.xxx.xxx:8123/
My Firewall Rules are NAT TCP * 443 → hassio:8123
NAT TCP * 8123 → hassio:8123
All are running, but the Android App can’t connect to my hassio Server from the lokal WLAN.
There are my Settings are:
Home Assistant-URL: https://url.duckdns.org
WLAN SSID: xxx
Internal URL: https://192.168.xxx.xxx:8123
I can open my Browser from my lokal WLAN and can open the Website.
From the App i can only connect to hassio with WLAN offline
Any idears?
My configuration is:
internal: http://192.168.xxx.xxx:8123/
https for external and http (not https) for internal…
on app or hassio or both?
That was going to be my first ask. Is SSL actually active on the internal port? You said you could ‘hit it from a browser on the internal address’ was that with SSL or no?
internal/external is ssl only.
internal http doesen’t work
I gave my configuration in the configuration.yaml file…
I am using duckdns and NGINX. I have two HA instances on two different sites: it is working fine on one site but not on the other one (I cannot access HA using the https://url.duckdns.org/ or the android app when I am on the LAN on the second site)… Based on what I searched on the net, this is a NAT issue but did not investigate more than that as when on the LAN on the second site, I use my PC to access HA via the internal URL (http)…
So when you are on the lan and you type the external link in a web browser (https://url.duckdns.org/), do you access HA ?
