Since my phone updated to the latest version 2023.3.0-full it’s taking ages to load and be able to navigate the dashboard, normally around 30 seconds when it’s been more than a few hours or the network has changed between mobile and wifi, subsequent opens are around 10seconds
Is anyone else noticing this?
MaxK
(Mark)
April 3, 2023, 11:38am
2
Could it be this issue?
opened 03:29AM - 04 Mar 23 UTC
bug
webview
<!-- READ THIS FIRST:
- Make sure you run the latest version of the Android app…
- Make sure you run the latest version of Home Assistant
- Make sure to check the Companion docs for troubleshooting and configuration: https://companion.home-assistant.io/
- Make sure the bug you found is not already reported, we love to put work in bugfixes instead of closing duplicate bug reports
DO NOT DELETE ANY TEXT from this template! All requested information is important.
**Home Assistant Android app version(s):**
2023.1.1-full
**Android version(s):**
13
**Device model(s):**
pixel 4a
**Home Assistant version:**
2023.2.5 HA OS
**Last working Home Assistant release (if known):**
**Description of problem, include YAML if issue is related to notifications:**
The Android mobile app is intermittently slow to startup (5-10 seconds to start) and slow when navigating in the app (up to 5 seconds to navigate to a different screen). The issue is persistent when it occurs until the phone is rebooted. This issue has been reported by others in the Home Assistant Forum
https://community.home-assistant.io/t/mobile-app-2022-11-0-full-slow-lately-solved-after-reset-but-now-slow-again/504816
https://community.home-assistant.io/t/ha-app-has-become-slow-on-android/534341/6
- For Wear OS devices we will need the LogCat logs from the device.
- For Android Auto the logs can be retrieved from the connected device.
- Logs from the device can be taken from Settings > Companion App > Show and Share Logs
**Companion App Logs:**
[homeassistant_companion_log_1-28-2023_5-59-6.txt](https://github.com/home-assistant/android/files/10887361/homeassistant_companion_log_1-28-2023_5-59-6.txt)
**Screenshot or video of problem:**
**Additional information:**
WebView version: 110.0.5481.153
No custom cards
No HACS components
Reloading the integration solves this for most users.
I would say that’s the one! Like others mention it’s unusable the way it is. Lucky HA is so awesome I rarely have to open the app these days
