I’m trying to use the Android app “Home Assistant” to create a shortcut on my home screen to a specific dashboard, using this guide:
I’ve tried a range of options for the “Dashboard View or Dashboard”, but cannot find one that works.
Issue 1.
When I use the “/lovelace/default_view” option defined in the guide, the Overview dashboard always appears, irrespective of whatever dashboard I have set up as the default.
Issue 2.
When I use the format “/lovelace-dashboardname/viewname” defined in the guide, I get “Unable to Connect to Home Assistant” message, For example, I have a dashboard named “LightsEtc” with a view “Home” (and here is a confusion, I type in “Home” when I set it up, but going into edit the dashboard from the Ui, it is shown as “HOME”). I have used both “lovelace-LightsEtc/Home” and “lovelace-LightsEtc/HOME” and both give the same message.
is there anyone who has sucessfully used the Android app to create shortcuts successfully who would critique what I have done and offer some suggestions on what I am doing wrong, or could do differently, or share there experience of how they achieved success.
Thanks in advance…
