Android APP "Unable to connect to Home Assistant"
No luck. Anyway to track error logs?
App logs are under App Configuration, you can check HA server logs and there is also chrome remote debugging to look at the frontend errors but that will require using a debug build of the app and a bit of fiddling. App Configuration and HA server logs are your best bet. Also referring to the troubleshooting sections of the docs may be of help if you haven’t looked at them all yet.
I have the same problem.
My situation:
Huawei MediaPad T3 Android 7.0 HomeAssistant 2021.9.0
HomeAssistant 2021.9.3 installed on Proxmox
I can login by Google Chrome with any device including Huawei, but I can’t login by HomeAssistant app on it. If I gave wrong password, notification appears in HomeAssistant, but if I gave correct password I have an error on app and no any logs on HA.
I have 3 phones connected with HomeAssistant and everything works fine. I tried new account, different WiFi network, wiping any data from app settings in android. Nothing works… Can someone fix this?
My situation:
Redmi Note 4 Android 7.0 HomeAssistant 2021.9.0
HomeAssistant 2021.9.3 installed on Raspberry Pi, Operating System: Home Assistant OS 6.3, core-2021.9.5, supervisor-2021.09.0,
I can login by Google Chrome with any device (including my phone (Redmi)), but I can’t login by HomeAssistant app on it. Also, if I gave wrong password, notification appears in HomeAssistant, but if I gave correct password I have an error on app and no any logs on HA.
make sure that chrome and/or android system webview are up to date. If you are on a custom ROM then you need to ensure googles version of webview is being used.
Android system webview is up to date, ROM is original from Huawei
are all of you guys using a proxy? If you take it out of the loop and make it a direct connection is it working?
For my phone ROM is original, I don’t use proxy.
since you guys are unable to get past initial onboarding can you get the ADB logs off the device itself? We should see some error in there that might give us a clue. There are some apps in the play store but keep in mind they will require you to plug your device into a computer to get full logging details. Once there you can reproduce the issue and hopefully logs will tell us whats going on.
C:\Users\Grzegorz> adb logcat | findstr io.homeassistant.companion.android
09-10 10:54:52.698 16996 16996 I BeaconManager: BeaconManager started up on pid 16996 named 'io.homeassistant.companion.android' for application package 'io.homeassistant.companion.android'.  isMainProcess=true
09-10 10:54:52.992 16996 17065 I FA      :   adb shell setprop debug.firebase.analytics.app io.homeassistant.companion.android
09-10 10:54:53.085 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:54:53.085 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:54:53.085 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:54:53.085 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:54:53.090 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:54:53.090 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:54:53.090 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:54:53.090 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:54:53.096 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:54:53.096 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:54:53.096 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:54:53.096 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:54:53.100 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:54:53.100 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:54:53.100 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:54:53.100 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:54:53.103 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:54:53.103 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:54:53.103 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:54:53.103 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:54:53.107 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:54:53.107 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:54:53.107 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:54:53.107 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:55:01.546  2204  2475 I ash     : running package: io.homeassistant.companion.android, visible: false
09-10 10:55:01.861 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:01.861 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:01.861 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:01.861 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:55:01.865 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:01.865 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:01.865 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:01.865 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:55:01.890 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:01.890 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:01.890 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:01.890 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:55:01.904 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:01.904 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:01.904 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:01.904 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:55:01.908 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:01.908 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:01.908 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:01.908 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:55:01.923 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:01.923 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:01.923 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:01.923 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:55:05.453   577   679 I AwareLog: HibSTrategy::HibStrategySwapCandidateProcessAdd packagename io.homeassistant.companion.android
09-10 10:55:05.598   577  2636 I AwareLog: HibStrategy::HibStrategySwapCandidateProcessRemove packagename is io.homeassistant.companion.android
09-10 10:55:07.490 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:07.490 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:07.490 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:07.490 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:138)
09-10 10:55:07.498 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:07.498 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:07.498 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:07.498 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:138)
09-10 10:55:07.504 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:07.504 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:07.504 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:07.504 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:138)
09-10 10:55:07.507 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:07.507 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:07.507 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:07.507 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:138)
09-10 10:55:07.512 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:07.512 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:07.512 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:07.512 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:138)
09-10 10:55:07.519 16996 17049 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:55:07.519 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:55:07.519 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:55:07.519 16996 17049 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:138)
09-10 10:55:16.589  2204  2475 I ash     : io.homeassistant.companion.android { running duration=15043 } transition to: doze reason:
09-10 10:55:16.589  2204  2475 I ash     : doze package: io.homeassistant.companion.android, visible: false
09-10 10:55:31.692  2204  2475 I ash     : io.homeassistant.companion.android { doze duration=15103 } transition to: hibernation reason:
09-10 10:55:31.694  2204  2475 I ash     : io.homeassistant.companion.android is unified heartbeat(ms): 300000 reason: hibernation
09-10 10:55:31.695  1483  1520 I PGManagerService: proxyBroadcast:[io.homeassistant.companion.android] proxy:true
09-10 10:55:31.696  2204  2475 I ash     : proxy io.homeassistant.companion.android broadcast OK !
09-10 10:55:31.698  2204  2475 I ash     : proxy app:io.homeassistant.companion.android,uid:10144,result:true
09-10 10:55:31.700  2204  2475 I PGServer: report state:6 event type:1 pid:0 uid:10144 pkg:io.homeassistant.companion.android to pid: 1483
09-10 10:55:31.700  2204  2475 I ash     : Freeze io.homeassistant.companion.android OK !
09-10 10:55:31.711  2204  2475 I ash     : add listener io.homeassistant.companion.android net packet OK !,uid:10144
09-10 10:55:32.886  2204  2475 I ash     : android send broadcast:android.intent.action.SCREEN_OFF notify package: io.homeassistant.companion.android, pid: 16996
09-10 10:55:32.886  2204  2475 I ash     : screen off io.homeassistant.companion.android H to D, reason:bc_notify_android.intent.action.SCREEN_OFF
09-10 10:55:32.886  2204  2475 I ash     : io.homeassistant.companion.android { hibernation duration=1194 } transition to: doze reason:bc_notify_android.intent.action.SCREEN_OFF
09-10 10:55:32.889  2204  2475 I PGServer: report state:6 event type:2 pid:0 uid:10144 pkg:io.homeassistant.companion.android to pid: 1483
09-10 10:55:32.889  2204  2475 I ash     : Unfreeze io.homeassistant.companion.android OK !
09-10 10:55:32.891  1483  2246 I PGManagerService: proxyBroadcast:[io.homeassistant.companion.android] proxy:false
09-10 10:55:32.894  2204  2475 I ash     : unproxy io.homeassistant.companion.android broadcast OK !
09-10 10:55:32.894  2204  2475 I ash     : cancel unified heartbeat: io.homeassistant.companion.android reason:left H
09-10 10:55:32.895  2204  2475 I ash     : unproxy app:io.homeassistant.companion.android,uid:10144,result:true
09-10 10:55:32.896  2204  2475 I ash     : doze package: io.homeassistant.companion.android, visible: false
09-10 10:55:32.902  2204  2475 I ash     : android send broadcast:android.intent.action.SCREEN_OFF notify package: io.homeassistant.companion.android, pid: 16996
09-10 10:55:37.522  2204  2475 I ash     : io.homeassistant.companion.android { doze duration=4627 } transition to: end, reason:stop_ash
09-10 10:58:56.397  2204  2481 I PGServer: report state:10000 event type:1 pid:0 uid:0 pkg:io.homeassistant.companion.android to pid: 2204
09-10 10:58:56.397  2204  2481 I SceneReceiver: state type: 10000 eventType:1 pid:0 uid:0 pkg:io.homeassistant.companion.android
09-10 10:58:56.397  2204  2634 I HwThermalStateManager: current foreapp pkg : io.homeassistant.companion.android
09-10 10:58:57.078 18385 18439 I FA      :   adb shell setprop debug.firebase.analytics.app io.homeassistant.companion.android
09-10 10:58:57.409 18385 18425 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:58:57.409 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:58:57.409 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:58:57.409 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:58:57.416 18385 18425 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:58:57.416 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:58:57.416 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:58:57.416 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:58:57.424 18385 18425 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:58:57.424 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:58:57.424 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:58:57.424 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:58:57.427 18385 18425 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:58:57.427 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:58:57.427 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:58:57.427 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:58:57.433 18385 18425 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:58:57.433 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:58:57.433 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:58:57.433 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:58:57.439 18385 18425 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request register_sensor
09-10 10:58:57.439 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.registerSensor(IntegrationRepositoryImpl.kt:473)
09-10 10:58:57.439 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver.updateSensors(SensorReceiver.kt:172)
09-10 10:58:57.439 18385 18425 E SensorReceiver:        at io.homeassistant.companion.android.sensors.SensorReceiver$onReceive$2.invokeSuspend(SensorReceiver.kt:133)
09-10 10:58:57.894  1483  1619 I ActivityManager: Displayed io.homeassistant.companion.android/.onboarding.OnboardingActivity: +513ms (total +1s614ms)
09-10 10:59:00.980  2204  2291 I AppTypeRecognise: input start front pkg: io.homeassistant.companion.android
09-10 10:59:01.888  1483  1847 E HwCHRWebMonitor: running processName=io.homeassistant.companion.android
09-10 10:59:01.890  1483  1847 E HwCHRWebMonitor: HwCHRWifiUIDWebSpeed [appName=io.homeassistant.companion.android UID=10144  WEBSENDSEGS=9  WEBRESENDSEGS=0  WEBRECVSEGS=10  WEBERRSEGS=0  WEBOUTRSTS=0  WEBESTABLISRST=0  WEBRTTDURATION=7  WEBRTTSEGS=4  WEBSNDDUPACKS=0  suckTimes=0 recovage_times=0]
09-10 10:59:11.936  1483  1847 E HwCHRWebMonitor: running processName=io.homeassistant.companion.android
09-10 10:59:15.748  2204  2291 I AppTypeRecognise: new im app: io.homeassistant.companion.android sent bytes:3610 count: 3 scron hours:0
09-10 10:59:15.748  2204  2291 I AppTypeRecognise: new im app: io.homeassistant.companion.android sent bytes:3610 front send count: 2 scron hours:0
09-10 10:59:19.840  2204  2291 I AppTypeRecognise: input start front pkg: io.homeassistant.companion.android
09-10 10:59:21.957  1483  1847 E HwCHRWebMonitor: running processName=io.homeassistant.companion.android
09-10 10:59:26.969  1483  1847 E HwCHRWebMonitor: running processName=io.homeassistant.companion.android
09-10 10:59:32.082  1483  1847 E HwCHRWebMonitor: running processName=io.homeassistant.companion.android
09-10 10:59:37.087  1483  1847 E HwCHRWebMonitor: running processName=io.homeassistant.companion.android
09-10 10:59:40.046  2204  2291 I AppTypeRecognise: new im app: io.homeassistant.companion.android sent bytes:949 count: 4 scron hours:0
09-10 10:59:42.096  1483  1847 E HwCHRWebMonitor: running processName=io.homeassistant.companion.android
09-10 10:59:42.097  1483  1847 E HwCHRWebMonitor: HwCHRWifiUIDWebSpeed [appName=io.homeassistant.companion.android UID=10144  WEBSENDSEGS=7  WEBRESENDSEGS=0  WEBRECVSEGS=7  WEBERRSEGS=0  WEBOUTRSTS=0  WEBESTABLISRST=0  WEBRTTDURATION=9  WEBRTTSEGS=3  WEBSNDDUPACKS=0  suckTimes=0 recovage_times=0]
09-10 10:59:47.110  1483  1847 E HwCHRWebMonitor: running processName=io.homeassistant.companion.android
09-10 10:59:52.113  1483  1847 E HwCHRWebMonitor: running processName=io.homeassistant.companion.android
C:\Users\Grzegorz>
And full logcat from 2nd attempt
not really seeing anything that jumps out at me but I keep seeing errors from this app HwCHRWebMonitor which is odd as I have never seen it. I imagine this might be something specific to your device. Have you checked its fully up to date? Can you confirm if googles version of android system webview is indeed the default on your device?
Hmmm, that’s strange, but my Android System WebView was disabled for some reasone. Probably in Android 7.0 it is disabled by default. I made these steps How to enable Android system web view in Android 7 - Quora but enabled android system webview doesn’t solve the problem. Error was the same, but Initializing was a little bit longer than with Chrome WebView.
That’s strange in general, because that app worked for some time on this device. There was no any system updates etc. at that time.
if your device has android system webview disabled then you need to keep chrome up to date. Since you said you use proxmox if you haven’t already you should check out the troubleshooting section in the docs. If you take proxmox out of hte loop does the app work?
What do you mean?
I don’t use NGINX proxy or something like this. I use DuckDNS and earlier everything works. Also I don’t want to remove Proxmox.
I reset my device to factory settings and problem still exists :frowning:
I changed the android phone to Xiaomi Mi note 10 and everything works
I’m still having issues on my iPhone 11 running iOS 15. Anyone else having issues.
Yes (Samsung Note 5 though).
I think that can be HomeAssistant Core/OS problem, not necessarily mobile app
