Does someone know how to deal with a car (volvo) that has 2 profiles setup and companion app installed?
On both profiles I installed the home assistant android auto companion app
It now displays in home assistant 2 devices for each profile a device.
The not selected profile is not updating as soon as you switch profiles
Any ideas how to resolve this?
not following your issue, you installed the app on 2 profiles but what is not updating? did you make sure to login and give a unique name for each profile?
Yes correct, made 2 profiles in the car, in both installed home assistant an logged in succesfully.
In home assistant in the mobile integratationnhave 2 devic entries.
Only the active profile in the car s updating
As a result one of the two profiles of the car is still on the parking lot of the grocery store. While in real life it is standing on the driveway
That’s to be expected, the other profile probably doesn’t let the app run in the background like it needs to when it is not in use.
I thought indeed the same, Is there a way to combine these as a single mobile device in home assistant?
It would by nice to tell to the integration that they are the same and only the state of the active one should be taken into account.
