I am currently using Spectrum as my home internet provider. Spectrum will tell me the (dynamic) public IP address to my router. I have Home Assistant installed on a Raspberry Pi 3. I can tell my Spectrum router to reserve an internal IP address for the Raspberry Pi 3 (192.168.1.26 in this case) and to forward port 8123 to that internal IP.
I have installed the Android Companion App and set its Home Assistant URL to http://<public_ip_address>:8123. When my phone is not on my home wifi network, I can access Home Assistant from my phone with that setting. This setting also works when I am connected to random outside wifi networks. I do not need Duck DNS, and I’m willing to change the Companion App’s URL if and when Spectrum changes my home public IP address.
However, when my phone is connected to my home wifi network, the Home Assistant URL setting of http://<public_ip_address>:8123 does not work. The settings in the Android Companion App for the “Internal Connection URL” setting and the “Prioritize Internal URL” switch are disabled. But these are the settings I believe I want to change, to prioritize and use my configured internal IP address when I’m on my home wifi network. Is this correct?
I tried updating my configuration.yaml file and adding the following lines:
homeassistant:
external_url: "http://XX.YY.ZZ.215:8123"
internal_url: http://192.168.1.26:8123
However, the Internal Connection URL setting in the Companion App does not seem to be affected by these configuration settings, and I assume that the configuration.yaml file only affects the HA server, and not the Companion App, is this correct?
What is really confusing to me is that the Companion App does not contain the SSID of my home wifi network. How does the Companion App know that I’m on my home wifi network without me setting the SSID? Why does it care, and why does it stop working? Why doesn’t it just go to the configured public IP address and work, just like when it’s on outside wifi network?
Either way, how can I enable the Internal Connection URL and the Prioritize Internal URL settings on the Android Companion App?
Thanks!
Home Assistant Android version: 2022.6.0
Android version: 11
Phone model: Moto G Power
Home Assistant version: 2022.6.7
