--------- beginning of main
09-12 20:50:42.155 19611 19611 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: true, expireMillis: 1694573418918, currentMillis: 1694573442155)
09-12 20:50:42.199 19611 19611 D LocBroadcastReceiver: Received location update.
09-12 20:50:42.201 19611 19611 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
09-12 20:50:42.201 19611 10829 D LocBroadcastReceiver: Last Location:
09-12 20:50:42.201 19611 10829 D LocBroadcastReceiver: Coords:(39.4219232, -104.7791542)
09-12 20:50:42.201 19611 10829 D LocBroadcastReceiver: Accuracy: 53.846397
09-12 20:50:42.201 19611 10829 D LocBroadcastReceiver: Bearing: 0.0
09-12 20:50:42.202 19611 10829 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
09-12 20:50:42.202 19611 10829 D LocBroadcastReceiver: Received location that is 49 milliseconds old, 1694573442153 compared to 1694573442202 with source fused
09-12 20:50:42.202 19611 10829 D LocBroadcastReceiver: Duplicate location received, not sending to HA
09-12 20:50:42.218 19611 19611 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: true, expireMillis: 1694573418918, currentMillis: 1694573442218)
09-12 20:50:42.218 19611 19611 D IntegrationRepository: setAppActive(): true
09-12 20:50:44.904 19611 19611 D SensorReceiver: Received intent: android.intent.action.SCREEN_OFF
09-12 20:50:44.905 19611 19611 D SensorReceiver: Sensor is_interactive corresponding to received event android.intent.action.SCREEN_OFF is disabled, skipping sensors update
09-12 20:50:44.908 19611 19611 D ButtonWidget: Broadcast received:
09-12 20:50:44.908 19611 19611 D ButtonWidget: Broadcast action: android.intent.action.SCREEN_OFF
09-12 20:50:44.908 19611 19611 D ButtonWidget: AppWidgetId: -1
09-12 20:50:44.910 19611 19611 D MediaPlayCtrlsWidget: Broadcast received:
09-12 20:50:44.910 19611 19611 D MediaPlayCtrlsWidget: Broadcast action: android.intent.action.SCREEN_OFF
09-12 20:50:44.910 19611 19611 D MediaPlayCtrlsWidget: AppWidgetId: -1
09-12 20:50:44.919 19611 10829 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:50:44.919 19611 19647 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=cc2060b3-d467-4603-8524-c68839855f18, tags={ io.homeassistant.companion.android.websocket.WebsocketManager } ]
09-12 20:50:45.838 19611 19611 D IntegrationRepository: setAppActive(): false
09-12 20:58:43.891 19611 19611 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1694573446838, currentMillis: 1694573923891)
09-12 20:58:43.988 19611 19611 D IntegrationRepository: setAppActive(): false
09-12 20:58:43.996 19611 19611 D LocBroadcastReceiver: Received location update.
09-12 20:58:43.997 19611 19611 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
09-12 20:58:43.997 19611 10829 D LocBroadcastReceiver: Last Location:
09-12 20:58:43.997 19611 10829 D LocBroadcastReceiver: Coords:(39.4219232, -104.7791542)
09-12 20:58:43.997 19611 10829 D LocBroadcastReceiver: Accuracy: 100.0
09-12 20:58:43.997 19611 10829 D LocBroadcastReceiver: Bearing: 0.0
09-12 20:58:43.997 19611 10829 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
09-12 20:58:43.997 19611 10829 D LocBroadcastReceiver: Received location that is 99 milliseconds old, 1694573923898 compared to 1694573923997 with source fused
09-12 20:58:43.997 19611 10829 D LocBroadcastReceiver: Duplicate location received, not sending to HA
09-12 20:58:44.013 19611 19611 D SensorReceiver: Received intent: android.intent.action.SCREEN_ON
09-12 20:58:44.013 19611 19611 D SensorReceiver: Sensor is_interactive corresponding to received event android.intent.action.SCREEN_ON is disabled, skipping sensors update
09-12 20:58:44.016 19611 19611 D ButtonWidget: Broadcast received:
09-12 20:58:44.016 19611 19611 D ButtonWidget: Broadcast action: android.intent.action.SCREEN_ON
09-12 20:58:44.016 19611 19611 D ButtonWidget: AppWidgetId: -1
09-12 20:58:44.019 19611 10829 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:44.020 19611 19637 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=d50b3ed4-330e-41c3-b819-e4a4d2735bdc, tags={ io.homeassistant.companion.android.websocket.WebsocketManager } ]
09-12 20:58:44.026 19611 19611 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:44.028 19611 19611 D MediaPlayCtrlsWidget: Broadcast received:
09-12 20:58:44.028 19611 19611 D MediaPlayCtrlsWidget: Broadcast action: android.intent.action.SCREEN_ON
09-12 20:58:44.028 19611 19611 D MediaPlayCtrlsWidget: AppWidgetId: -1
09-12 20:58:44.029 19611 19611 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:44.031 19611 19611 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:44.854 19611 19611 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1694573446838, currentMillis: 1694573924854)
09-12 20:58:45.220 19611 19611 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1694573446838, currentMillis: 1694573925220)
09-12 20:58:45.220 19611 19611 D IntegrationRepository: setAppActive(): true
09-12 20:58:54.437 19611 19611 D IntegrationRepository: setAppActive(): false
09-12 20:58:54.450 19611 19611 D WebviewActivity: Matter commissioning status changed to NOT_STARTED
09-12 20:58:54.451 19611 19611 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:54.452 19611 19611 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:54.452 19611 19611 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1694573935437, currentMillis: 1694573934452)
09-12 20:58:54.546 19611 19638 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:54.548 19611 19637 I WM-Processor: Moving WorkSpec (c219db9b-2e74-4139-b2d7-f42192faf5b7) to the foreground
09-12 20:58:54.558 19611 10829 D SensorWorker: Updating all Sensors in foreground.
09-12 20:58:54.558 19611 19637 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=eca5ff61-a60d-4f51-8795-d1b4ed420b27, tags={ io.homeassistant.companion.android.websocket.WebsocketManager } ]
09-12 20:58:54.558 19611 10829 D LastUpdate: Last update is SensorWorker
09-12 20:58:54.559 19611 19796 D WebviewActivity: External bus {“type”:“haptic”,“payload”:{“hapticType”:“failure”},“id”:5}
09-12 20:58:54.562 19611 10829 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:54.565 19611 19611 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android/androidx.work.impl.foreground.SystemForegroundService (has extras) }
09-12 20:58:54.565 19611 19611 D WebviewActivity: Processing haptic tag for failure
09-12 20:58:54.602 19611 19796 D WebviewActivity: External bus {“type”:“connection-status”,“payload”:{“event”:“disconnected”},“id”:6}
09-12 20:58:54.606 19611 10829 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:54.607 19611 10829 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:54.610 19611 19611 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:54.610 19611 19611 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1694573935437, currentMillis: 1694573934610)
09-12 20:58:54.620 19611 19611 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:54.620 19611 19611 D ServerConnectionInfo: Using cloud / remote UI URL
09-12 20:58:54.621 19611 19611 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:54.621 19611 19611 D ServerConnectionInfo: Using cloud / remote UI URL
09-12 20:58:54.626 19611 19611 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
09-12 20:58:54.631 19611 19611 D LocBroadcastReceiver: Got single accurate location update: Location[fused 39.421923,-104.779154 hAcc=100.0 et=+4h54m22s275ms alt=1854.5 vAcc=100.0]
09-12 20:58:54.631 19611 19611 D LocBroadcastReceiver: Location accurate enough, all done with high accuracy.
09-12 20:58:54.632 19611 19611 D LocBroadcastReceiver: Last Location:
09-12 20:58:54.632 19611 19611 D LocBroadcastReceiver: Coords:(39.4219232, -104.7791542)
09-12 20:58:54.632 19611 19611 D LocBroadcastReceiver: Accuracy: 100.0
09-12 20:58:54.632 19611 19611 D LocBroadcastReceiver: Bearing: 0.0
09-12 20:58:54.632 19611 19611 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
09-12 20:58:54.632 19611 19611 D LocBroadcastReceiver: Received location that is 9782 milliseconds old, 1694573924850 compared to 1694573934632 with source fused
09-12 20:58:54.632 19611 19611 D LocBroadcastReceiver: Duplicate location received, not sending to HA
09-12 20:58:54.710 19611 28468 D TrafficStats: tagSocket(241) with statsTag=0xffffffff, statsUid=-1
09-12 20:58:54.710 19611 28458 D TrafficStats: tagSocket(257) with statsTag=0xffffffff, statsUid=-1
09-12 20:58:55.510 19611 19796 D WebviewActivity: External bus {“type”:“connection-status”,“payload”:{“event”:“connected”},“id”:7}
09-12 20:58:55.512 19611 19611 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:55.583 19611 10829 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:55.846 19611 10829 I SensorReceiver: Sensor updates and sync completed
09-12 20:58:55.846 19611 19637 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=c219db9b-2e74-4139-b2d7-f42192faf5b7, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
09-12 20:58:55.849 19611 19611 I WM-SystemFgDispatcher: Stopping foreground service
09-12 20:58:55.909 19611 19611 D LocBroadcastReceiver: Got single accurate location update: Location[fused 39.421927,-104.779153 hAcc=11.492 et=+4h54m33s5ms alt=1854.5 vAcc=1.3092893]
09-12 20:58:55.909 19611 19611 D LocBroadcastReceiver: Location accurate enough, all done with high accuracy.
09-12 20:58:55.910 19611 19611 D LocBroadcastReceiver: Last Location:
09-12 20:58:55.910 19611 19611 D LocBroadcastReceiver: Coords:(39.4219274, -104.7791533)
09-12 20:58:55.910 19611 19611 D LocBroadcastReceiver: Accuracy: 11.492
09-12 20:58:55.910 19611 19611 D LocBroadcastReceiver: Bearing: 0.0
09-12 20:58:55.911 19611 19611 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
09-12 20:58:55.911 19611 19611 D LocBroadcastReceiver: Received location that is 331 milliseconds old, 1694573935580 compared to 1694573935911 with source fused
09-12 20:58:55.913 19611 22075 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:55.931 19611 19796 D WebviewActivity: External bus {“type”:“theme-update”,“id”:8}
09-12 20:58:55.941 19611 19611 D WebviewActivity: Color from webview is “#101e24-SPACER-#111111”
09-12 20:58:55.941 19611 22075 D WebViewPresenterImpl: Try getting color from webview color “#101e24”.
09-12 20:58:55.942 19611 22075 I WebViewPresenterImpl: Found color -15720924.
09-12 20:58:55.942 19611 22075 D WebViewPresenterImpl: Try getting color from webview color “#111111”.
09-12 20:58:55.942 19611 22075 I WebViewPresenterImpl: Found color -15658735.
09-12 20:58:56.066 19611 22075 D LocBroadcastReceiver: Location update sent successfully for 4 as exact
09-12 20:58:57.928 19611 19796 D WebviewActivity: External bus {“type”:“config_screen/show”,“id”:9}
09-12 20:58:57.939 19611 19611 D IntegrationRepository: setAppActive(): false
09-12 20:58:57.940 19611 19611 D IntegrationRepository: setAppActive(): false
09-12 20:58:57.957 19611 19611 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1694573935437, currentMillis: 1694573937957)
09-12 20:58:57.995 19611 19611 D SensorReceiver: Received intent: io.homeassistant.companion.android.UPDATE_SENSORS
09-12 20:58:57.996 19611 19611 D LastUpdate: Last update is io.homeassistant.companion.android.UPDATE_SENSORS
09-12 20:58:57.999 19611 22075 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:58.000 19611 10829 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:58.018 19611 19611 D SettingsWearDetection: API unavailable for discovering nodes (no Wear)
09-12 20:58:58.029 19611 19611 D LocBroadcastReceiver: Not requesting accurate location, last accurate location was too recent
09-12 20:58:58.029 19611 19611 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
09-12 20:58:58.039 19611 22075 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:58.053 19611 28458 D TrafficStats: tagSocket(222) with statsTag=0xffffffff, statsUid=-1
09-12 20:58:58.108 19611 19611 D IntegrationRepository: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1694573935437, currentMillis: 1694573938108)
09-12 20:58:58.108 19611 19611 D IntegrationRepository: setAppActive(): true
09-12 20:58:58.226 19611 22075 D ServerConnectionInfo: localUrl is: false, usesInternalSsid is: false, usesWifi is: true
09-12 20:58:58.375 19611 22075 I SensorReceiver: Sensor updates and sync completed
09-12 20:59:04.592 19611 22075 D LogcatReader: Read logcat for pid 19611
