Hi everyone,
I’m a total beginner at home assistant and I’m trying to set widgets on my android home screen to control some of my smart devices. I want to use the entity state widget because I like the fact that I can see the state and toggle the device as well.
However, when setting up my widget, I can only display the state and the name of the device. If I activate the attribute section and select icon for example, the widget shows the ID of the icon instead of the image (see screenshot below)
Anyone having the same issue ? Is there a parameter that I need to activate ?
Thanks for any advice you can provide
