I have one android ip webcam instance since ages when the config had to be done via configuration.yaml where I listed all the sensors I wanted. Then, at some point, the integration got it is webui so I moved the config. But now a bunch of sensors are missing and also the “torch” switch is missing.
Is there a way to bring the old sensors/switches back?
also, what do you call the process of making integration configurable via the webui?
