My ShieldTV continuously shows this prompt, ticking remember this computer does nothing. What’s going on? I have the latest version of Home Assistant. I found a similar post from more than two years ago and which stated that this was fixed in version 0.114 - but version 0.114 of what?
I am getting this same prompt allowing and checking always allow does nothing. The only way I can get past it is to use the Nvidia Shield app and select the app on the shield I want to watch.
I actually had do uninstall the AndroidTV integration from HA to make this continuous prompt go away. Just for fun, I decided to install it again just now and I got two prompts which I accepted and ticked “alwas blabla” and it seems to work now. I’m pretty sure it will start popping up continuously the next time I start my Nvidia Shield. Will post here again if /when that happens.
There we go. Turned on my Shield now and I could not get past this prompt. Had to uninstall the AndroidTV integration from Home Assistant and restart the Shield. I cannot believe we’re the only ones having this issue?
I am having the same issue. I also had to uninstall the AndroidTV integration to make the undismissable prompt go away on my Shield. That makes me sad because I had it set up to automate my theater lighting based on the ShieldTV play state.
