I’m trying to integrate android tv into HA and it doesn’t seem to be working.
In integations, it asks me for host, I presume I have to put an ip address of the tv in there, but that seem to work.
Secondly, I tried another way in config.yaml (see picture below) This gives me a config error. What am I doing wrong?
When you put ip address of android tv, you are supposed to give permission to incoming request from home assistant on your tv screen. Be sure that your tv is on and check if there are any permission requests pending
So at the moment I can turn it off, and change volume. Do you know how I can do more advanced things, like turning it on via lan, or chaneg source etc.
I have this exact same issue with my Philips TV POS9002. I’ve tried entering 1925 as the port value but that didn’t work for me and I’m stuck with the Failed to connect response. I’ve definitely enabled debugging on my TV (went through Android settings, enabled developer options and toggled the debugging switch on screen). Am stuck and would appreciate any pointers!
