Android TV Remote - looses pairing after HA restart
I have been using the Android TV remote integration since it was introduced and is really useful but…
It looses pairing after each restart of the Home assistant. The behavior is the same for HA installed as docker and HAOS
Any suggestion for setting I will need to change on the chromecast or HA to maintain the pairing?
Strange - am I the only one with the issue? I have tried all debugging steps I could find (disable ADB just in case, clear the cache of the remote control service, restart the device) nothing changed.
No , you are not the only one.
It has happened several times but I cannot confirm whether it is after a HA reboot, to me it seems random. Mine reads: ! Repair, Authentication Expired for [tv name] under Settings and Notifications (side bar), and Discovered / Reconfigure under Device & Services.
It is a TCL TV if that helps, but odd that it only happens on that one when there are three more TLC TVs of various sizes and models around the house.
I did come across this post which may be relevant to this issue: https://www.reddit.com/r/homeassistant/comments/10zsvim/samsung_tv_integration_loses_authorization_when/
Same issue here with a new TCL TV. Enabled developer options but I don’t see the usual options to NOT revoke authorization. I think this is a TCL firmware issue, where they just won’t allow persistent debugging/atv authorization.
Perhaps there is a way to edit these flags in Android? Outside of the developer options
Same for nvidia shield. Constantly loses pairing and it’s often time consuming to get it back. I usually have to clear data on the remote app. Also if the pairing code does not show up on the TV for some reason, I have to restart HA to try again. Someone said to type 0000 as the pair code to try again but that does not work for me.
Same thing happens to me, but it is not consistent with HA restart. But it keeps happening once a week, I have to pair again and again.
And sometimes it does not show the pin at all, not even when trying 0000.
Chromecast with Google TV.
Happening here too on an Nvidia Shield. Trying to use the prompt to reconfigure via the HA Repair notification doesn’t call up a PIN, so I end up having to delete the device and re-add from scratch. Developer options and network ADB enabled.
For me it is happening on Philips Signage Screen. It’s like the connection credentials are reset or something.
