Android TV to Standby/Ambient Mode
Hello HA Community!
After much frustration and lots of clicking around, I finally have my TCL Android TV integrated into HA. Now I’m integrating it into my automations using media_player.turn_on and media_player.turn_off to get it on and off when I come home or leave. Great.
My issue comes from when I’d like the TV to automatically start into ambient mode (to display my Google Photos album) which, whenever the TV automatically goes to ambient mode on it’s own, shows the TV status (on HA) as in Standby.
What I’m trying to get at is: is there a way to force an Android TV to Standby? Tried Developer Tools>set state but no luck.
Thanks for your help!
Did you find a solution to this? I’m trying to achieve the same thing.
Unfortunately, no. Although since then I purchased a screensaver app that displays my photos instead of the built in ambient mode. I haven’t tried anything to see if I can get that to launch…
Try this using android tv adb integration. This command starts the screen saver and in your case ambient mode
am start -n "com.android.systemui/.Somnambulator"
On the Google Chromecast with Google TV, on the home screen pressing back on the remote once or twice, takes it to ambient mode, it could be worth taking a look at that.
I think the idea was for home assistant to activate this without user input
found a work around, not the most elegant solution but it does work.
Basically it just like if you hit the home button on your remote once, then held the home button, then navigated to the screensaver.
  - service: remote.send_command
    metadata: {}
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: HOME
      entity_id: remote.onn_full_hd_streaming_device
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
    metadata: {}
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 2
      command: HOME
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
    metadata: {}
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: DPAD_DOWN
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
    metadata: {}
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: DPAD_LEFT
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
    metadata: {}
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: DPAD_CENTER
Just in case Google brings someone else here, it’s a bit easier now:
action: remote.send_command
  entity_id: remote.google_tv
  delay_secs: 0.4
  command: BACK
  num_repeats: 2
Sending Back twice is enough to start Ambient mode from the home screen.
Brilliant!
An issue with send two BACK commands is that this won’t always trigger ambient mode if you’re in another tab of the home screen such as the Live channel guide, or Apps etc., and you might exit ambient mode as soon as you enter it as the second BACK command can cause you to go back to the home screen.
You aren’t required to perform two back presses to enter Ambient mode, instead you have to press back only once when you are hovering over the “For you” navigation tab or whatever the main navigation tab is on your tv.
Once you’re on the home screen, you should begin by sending a HOME command twice, this will move to the “For you” button in the navigation bar no matter where you were in the home screen previously, and from here send a single BACK command which will trigger the Ambient Mode to turn on.
Here’s an example script which will work as long as the TV is turned on, it first goes to the home screen if it’s not there already, then performs the necessary actions to enter ambient mode from there.
alias: Android TV Remote Enable Ambient Mode
sequence:
  - if:
      - condition: state
        entity_id: remote.android_tv_remote
        state: com.google.android.apps.tv.launcherx
        attribute: current_activity
    then: []
    else:
      - action: remote.send_command
        metadata: {}
          command: HOME
      - wait_for_trigger:
          - trigger: state
            entity_id:
              - remote.android_tv_remote
            to: com.google.android.apps.tv.launcherx
        continue_on_timeout: false
        timeout:
          hours: 0
          minutes: 0
          seconds: 5
          milliseconds: 0
    metadata: {}
      command: HOME
      num_repeats: 2
    metadata: {}
      command: BACK
icon: mdi:television-off
