after integrating my new Beko washing machine via HomeWhiz, I am now working on a nicely animated lovelace card.
I tried my ways with custom-button card and browser-mod popup but it does not work:
Here is my code:
type: custom:button-card
entity: sensor.beko_waschmaschine_zustand
show_state: true
show_icon: false
show_name: true
tap_action:
action: fire-dom-event
browser_mod:
command: popup
card:
type: vertical-stack
cards:
- type: markdown
content: |
## Waschprogramm wählen
- type: entities
entities:
- entity: sensor.beko_waschmaschine_verbleibend
name: Zeit verbleibend
icon: mdi:clock-time-four-outline
- entity: sensor.beko_waschmaschine_zustand
icon: mdi:washing-machine
- entity: sensor.beko_waschmaschine_sub_zustand
icon: mdi:submarine
- entity: binary_sensor.beko_waschmaschine_die_tur_ist_offen
name: "Tür offen? "
icon: mdi:washing-machine-alert
- entity: binary_sensor.beko_waschmaschine_fernbedienung
icon: mdi:bluetooth-connect
- entity: select.beko_waschmaschine_programm
icon: mdi:form-select
- entity: sensor.beko_waschmaschine_dauer
icon: mdi:timer
- entity: select.beko_waschmaschine_temperatur
name: Auswahl Temperatur
icon: mdi:temperature-celsius
- entity: select.beko_waschmaschine_schleudern
name: Auswahl Schleudern
icon: mdi:fan-speed-3
- entity: select.beko_waschmaschine_zustand
icon: mdi:play-pause
- entity: switch.beko_waschmaschine_anticrease
icon: mdi:tshirt-v
- entity: switch.beko_waschmaschine_dampf
- entity: switch.beko_waschmaschine_einweichen
icon: mdi:hand-wash-outline
- entity: switch.beko_waschmaschine_extraspulung
icon: mdi:spray-bottle
- entity: switch.beko_waschmaschine_nachtmodus
icon: mdi:weather-night
- entity: switch.beko_waschmaschine_remote_knitterschutz
icon: mdi:remote-off
- entity: switch.beko_waschmaschine_tierhaarentfernung
icon: mdi:cat
- entity: switch.beko_waschmaschine_vorwasche
icon: mdi:skip-previous
- entity: select.beko_waschmaschine_fast
icon: mdi:run-fast
show_header_toggle: false
state_color: true
style:
width: 400px
styles:
card:
- width: 150px
- height: 200px
- border-radius: 15px
- overflow: hidden
- padding: 0px
img:
- width: 100%
- height: 100%
- object-fit: contain
- margin-top: "-10px"
name:
- font-size: 1.1em
state:
- font-size: 0.9em
- opacity: 0.8
state:
- operator: template
value: >
[[[ return
states['binary_sensor.beko_waschmaschine_die_tur_ist_offen'].state ===
'on'; ]]]
styles:
img:
- content: url("/local/images/waschmaschine_tuer_offen_rot.png")
- value: läuft
styles:
img:
- content: url("/local/images/waschmaschine_running.gif")
- value: fertig
styles:
img:
- content: url("/local/images/waschmaschine_fertig_gruen.png")
- value: Aus
styles:
img:
- content: url("/local/images/waschmaschine_aus.png")
- value: Ein
styles:
img:
- content: url("/local/images/waschmaschine_ein.png")
- value: unknown
styles:
img:
- content: url("/local/images/waschmaschine_default.png")
I tried to ask Gemini for help with the code and it suggested the following:
- Indentation errors: YAML is extremely sensitive to spaces. Every indentation must be correct. Most often, it’s 2 spaces per level.
- Incorrect image paths: The
/local/path must be correct, and the images need to be in your Home Assistant’swwwfolder (or a subfolder within it). - Incorrect entity IDs: Make sure that
sensor.beko_waschmaschine_zustandand binary_sensor.beko_waschmaschine_die_tur_ist_offen` are indeed the correct IDs for your entities. - Missing HACS cards: Are
custom:button-cardandcustom:browser_mod(orcustom:bubble-card) definitely installed and loaded in the browser cache? Sometimes refreshing the browser or clearing the cache helps. - Syntax errors within the button-card configuration: Even the smallest typos can break the entire card.
- Image format: Some images can cause problems (e.g., incorrect PNG/JPG format, corruption).
- as far as I can tell, the formatting is good
- image paths should be fine, I uploaded them with the exact names in /www/images
- entity names are all fine and work in other, simpler cards
- all addons installed
- should be fine? the code above is already optimized and pasted from Gemini
- the pictures display well after uploading when opening from file editor
anyone can help please?
