Hi all
type: custom:button-card
Hi, I recommend to look at the developer’s documentation…
- type: custom:button-card
icon: mdi:battery
entity: binary_sensor.movement_backyard
primary: worx
styles:
icon:
- color: >
if (entity.state === 'on') return 'green';
return 'gray';
- animation: >
if (entity.state === 'on') return 'charge 3s linear infinite;';
return 'none';
extra_styles: |
@keyframes charge {
0%, 80% { clip-path: inset(0 0 0 0); }
10% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 84%, 34% 84%, 34% 100%, 100% 100%, 100% 0%); }
20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 74%, 34% 74%, 34% 100%, 100% 100%, 100% 0%); }
30% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 54%, 34% 54%, 34% 100%, 100% 100%, 100% 0%); }
50% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 34%, 34% 34%, 34% 100%, 100% 100%, 100% 0%); }
70% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
Hi VietNgoc
Thanks a lot for you help. Its working perfect.
I will look into the developers documentation
Br Martin
