You can actually use the SDK for Wire-Pod now, without having to authenticate the bot via the app first.
This means I’ll restart this project - and it SHOULD be compatible with cloud-connected bots as well.
Amazing that you’re still investing into this.
Can’t emphasise the gratitude!
Thanks again
Great work! Is your current code state on GitHub? Thank you.
No, it’s only in a really buggy state on my dev-server Needs alot of TLC still.
I’ll let you know in here when there is something to test.
The first version I had working had a really laggy camerafeed, so I’m rebuilding the whole thing (had to enable EscapePod usage as well)
Hey even in a buggy state it’s still cool to see how it’s all going together fix by fix on GitHub. Don’t be shy, I’m sure the spaghetti code is better than most of us could do. Maybe people can help you poke at it as well or point interesting things out. Can’t wait to see what you have got going! I wish DDL didn’t cause so many issues and actually tried to make him better. I can barely get him to do anything now and the app crashes when I click options in it. Always feel sad when I have to say hey Alexa instead of Vector for him to respond to anything properly.
I get that But believe me - the code at the state it has now, is useless - it crashes on every refresh
Used today to do some bug-fixing, and actually have a working version (well partly at least)
Not much to show thou
DO REMEMBER - the state of this code is NOT production state, there IS errors and it will poteltially crash your Home Assistant installation, so ONLY use this on a test installation and if you are a hardcore Home Assistant user.
Eh - no?! This integrates with Vector - no matter if you use DDL servers, EscapePod or Wire-Pod.
One of my Vectors is on DDL servers and the other is on Wire-Pod, and both works with this integration.
Integration currently put into the grave.
I don’t have the time for this right now as I have a few other integrations I maintain and a few more important integrations in the making.
Haven’t given up on this, but as it’s current state isn’t working I have opted to remove the repo for now.
Thanks for the great effort!
Hi!
I know this was some time ago but did you ever consider bringing this project back to life? Would love to find a way for my Vectors to integrate into HA
Hope all is well
It’s still in my todo list, but not sure when I’ll get the time to revisit this integration
