ANNKE C500 Bullet camera
Has anyone tried the ANNKE C500 bullet camera. It has both RTSP and ONVIF. I want to use it with Frigate for object detection too
Most Annke are just rebranded (mostly lower end) Hikvision cameras. They will work fine.
Please note that it is important that the camera can work with the h264. The h265 is problematic because it is not supported by browsers so no image.
I bought two c800 I91BL0102 during promotion, unfortunately for the moment I have not managed to make them work in the frigate.
I read somewhere in the forum that H265 works but you need to convert it to H264 on the fly for processing.
Could you share the config for your ankle camera? I am trying to integrate c500 dome but I didn’t get it work
Did you get your camera working? Do you have a example config that you could provide?
