The latest security camera ANNKE C800 True 4K with Sony Sensor is here. I will connect the camera to ANNKE NVR (Network Video Recorder) which goes effortlessly, but it is interesting to see.
And because the camera & NVR bundle supports RTSP I will connect them to Home Assistant where I will try to expose the Camera motion sensor and I will try to create some Home Assistant automatons!
Sorry for answering to this old thread but I have a question that reference to exactly this video.
@kpeyanski
Did you get it working with H265 or H265+? My cameres only support these codecs. On what system do you run Home Assistant? When I check the rtsp stream I dont see any video only sound.
Hi, did you have luck with Person and Vehicle detection that is present on the last ANNKE Firmwares, as it seems not being available through home assistant integration (HIK / ONVIF).
Just curious.
My Dahua cameras connected using ONVIF do have a movement binary sensor which is set up in the camera to only trigger on vehicle or person detection (not the standard pixel change movement sensor). Only one binary sensor for both events though.
Using Scrypted NVR (not free) I can get separate mqtt events for all sorts of things, person, animal, vehicle. They are about a second slower than using the one ONVIF sensor.
